976292 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 14, 2026, 02:19 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  ns driver
Author Topic: ns driver  (Read 2069 times)
Offline oldtired
  • Dirty Old Man
ns driver
« on: July 03, 2012, 01:53 AM »
are all drivers the same size or are they specific to each hub,  ?
Re: ns driver
« Reply #1 on: July 03, 2012, 07:31 AM »
they will be specific to the Hub in general matey.....what Hub do you have?  ???
Offline oldtired
  • Dirty Old Man
Re: ns driver
« Reply #2 on: July 05, 2012, 03:10 PM »
cheers Rob thought that might be the case , no hub but found a cheap set of wheels , they're 9 tooth but didn't fancy the 25/9 gear, wanted an easy gear like the 41/16 i'm running at the mo so thought about going bigger on the back 11 maybe?  cheaper than going smaller on the front , new cranks ------- out of the budget at the mo  :'(  :LolLolLolLol:
Re: ns driver
« Reply #3 on: July 05, 2012, 03:26 PM »
depending on the hub, a new driver will cost you anything up to about £50 i think  ???
Offline oldtired
  • Dirty Old Man
Re: ns driver
« Reply #4 on: July 05, 2012, 03:31 PM »
 ???     25/9 then,     n get used to it  :daumenhoch:  :LolLolLolLol:
motomagII
Re: ns driver
« Reply #5 on: July 05, 2012, 03:44 PM »
25x9 is okay dude .but i got  a proper hub with 10t (because thats all they had and run 28 )
scan ebay and get a 23t front cheap used
Offline oldtired
  • Dirty Old Man
Re: ns driver
« Reply #6 on: July 05, 2012, 04:02 PM »
do the 23t fit normal crank mount Greg,   or do you kneed crank with the mount nearer the spindle?   if ya gets me
Re: ns driver
« Reply #7 on: July 05, 2012, 06:21 PM »
Yep I run 28/9 and it's great  :daumenhoch:
