976293 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 14, 2026, 03:39 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  tin foil & coke
Author Topic: tin foil & coke  (Read 2650 times)
Offline HUTCHMAN
tin foil & coke
« on: July 03, 2012, 09:06 PM »
Had a search but couldn't find the answer...when doing the tin foil & coke thing,which side of the foil....shiny or dull?
Offline Munnyella
Re: tin foil & coke
« Reply #1 on: July 03, 2012, 09:07 PM »
Screw it up, get a bit of each, it doesn't matter
Re: tin foil & coke
« Reply #2 on: July 03, 2012, 09:28 PM »
Best 2 use the dull side  ;) less scratches I believe
Offline kuwahero
    • Western Titans
Re: tin foil & coke
« Reply #3 on: July 03, 2012, 09:36 PM »
Re: tin foil & coke
« Reply #4 on: July 03, 2012, 10:44 PM »
don't use that shite  ::)  might as well rub your bellend on a brick  :crazy2:
Peek and then a Goddards cloth
read here ;)
http://www.radbmx.co.uk/forum/index.php'topic=120674.0
(any chance of a sticky so i don't have to keep looking for this thread  ;D)
Re: tin foil & coke
« Reply #5 on: July 04, 2012, 01:21 PM »
Used lemon juice and tin foil on this ........
Wheels before
Wheels after
Bottom bracket area before
and after
It does work  ;)
Re: tin foil & coke
« Reply #6 on: July 04, 2012, 02:02 PM »
Dull side, coke, lemon juice, anything like that will do it, the foil helps lift the rust.
Good work there Joff, looks great  :daumenhoch:
Re: tin foil & coke
« Reply #7 on: July 04, 2012, 02:41 PM »
i find vinegar and tin foil works best
lukethespookcoop
Re: tin foil & coke
« Reply #8 on: July 08, 2012, 10:15 PM »
I've tried the coke/tin foil approach on my seat post!, it wouldn't touch it!, is it cause it's a different quality chrome to the frame?.
Re: tin foil & coke
« Reply #9 on: July 08, 2012, 11:07 PM »
got pic?
