976289 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 12, 2026, 03:28 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Rock hard nuts.....
Author Topic: Rock hard nuts.....  (Read 5923 times)
Offline Orange777
Rock hard nuts.....
« on: July 12, 2012, 09:22 PM »
I have an SR one piece stuck on a GT Power Disk that I bought from the US....
I cannot shift it with a giant spanner, I cannot shift it with blow torch heat, large spanner and vice
In fact its officially stuck! I even took a chisel to it today and it was hardened so the bugger would not move......
Where do you take these things? I am not even sure what tools someone could use...
All help appreciated!!
Offline bobbbbsy
Re: Rock hard nuts.....
« Reply #1 on: July 12, 2012, 09:26 PM »
you mean the locking part of the bottom bracket is stuck on the crank ??
Offline Orange777
« Reply #2 on: July 12, 2012, 09:28 PM »
Hi,
Yes sorry......!! Will see if can dig a picture out... hang on :)
Offline Orange777
« Reply #3 on: July 12, 2012, 09:34 PM »
Photo of the swine
oldboyburner
« Reply #4 on: July 12, 2012, 09:35 PM »
Undoing anticlockwise ? :daumenhoch:
May need a vice
Offline Orange777
« Reply #5 on: July 12, 2012, 09:37 PM »
May need a vice
Tried the vice.......
Tried both ways, clock and anti - won't move a gnats!
Offline bobbbbsy
« Reply #6 on: July 12, 2012, 09:38 PM »
oh them ones are a bitch yeah ! you tried a bit of shocking? hammertime ? 2 man effort ?
oldboyburner
« Reply #7 on: July 12, 2012, 09:39 PM »
Anti clockwise only mate keep at it in the vice
Offline Orange777
« Reply #8 on: July 12, 2012, 09:43 PM »
Had a two man attempt, with the vice - anti clockwise with a blow torch........it won't shift!
Hammers, the lot........ does anyone ever glue these??
Offline bobbbbsy
« Reply #9 on: July 12, 2012, 09:43 PM »
id probably try a lump/club/mini sledge hammer on the spanner end or if all else fails the bike shop where they have loads of big park tools spanners and appropriate work bench!
« Reply #10 on: July 12, 2012, 09:47 PM »
Apply some physics to the equation  :daumenhoch: find a long steel tube that will fit over your spanner and the extra leverage should pop it off no problem  ;)
Offline Orange777
« Reply #11 on: July 12, 2012, 09:51 PM »
The spanner I tried today is for a HGV, its about 3 foot long...... did nothing with two of us pushing it! :(
Thanks for Physics tip though - good call!
« Reply #12 on: July 12, 2012, 09:57 PM »
Christ  :shocked: errrr... double the length quadruple the force.... or summat like that.
Try a longer lever  :daumenhoch:
Offline Orange777
« Reply #13 on: July 12, 2012, 10:03 PM »
Going to try the longer shaft method.
Failing that - not even sure where could take it to! Maybe a bus depot? Do we still have them in 2012?
« Reply #14 on: July 12, 2012, 10:05 PM »
have you tried turning it off and on again  ???
Offline Orange777
« Reply #15 on: July 12, 2012, 10:09 PM »
Not tried that yet Bendycat! Very shortly it's going to fly off a 4th floor balcony! :)
Offline bobbbbsy
« Reply #16 on: July 12, 2012, 10:10 PM »
i delivered to one the other day ! there are commercial vehicle service / repair depots to !
Offline Orange777
« Reply #17 on: July 12, 2012, 10:14 PM »
Thanks for suggestions. Will see what I can find locally. Engineers or bus depots. Have a feeling that in this quest of man vs. machine, machine wins! :(
« Reply #18 on: July 12, 2012, 10:16 PM »
Never yet been bested with stuck nuts when i've used a long lever. The creak/ snap sound as it finally gives in to pure science is satisfaction guaranteed  :daumenhoch:
volvo amazon wheel nut
Lambretta kick stand bolt
Datsun 100a exhaust mount bolt
and many others have all resisted wd40, blow torches, diesel, freezing and a few other methods but ALL have secummed to a mighty lever
  >:D >:D >:D  ;D
« Reply #19 on: July 12, 2012, 10:18 PM »
pour some coke~a~cola on it and and if you can make it stay there, then the coke will loosen the rust which is locking it on  ;)
Offline Orange777
« Reply #20 on: July 12, 2012, 10:28 PM »
Old school ace you are the king of nuts!!
Thanks Bendycat - do you mean leave soaking in a coke bath?
Would overnight be long enough? Will get 4 litre of coke.
Cheers!!!! :)
« Reply #21 on: July 13, 2012, 12:49 AM »
yup bath time - but same some to have with some whisky  ;)
Offline GTnumber1
« Reply #22 on: July 13, 2012, 06:47 PM »
send to me, if i get it off il keep the disc  :LolLolLolLol:
Offline Orange777
« Reply #23 on: July 13, 2012, 08:17 PM »
A very kind offer Steve!!!
Thanks..........if all else fails guess its yours!!
« Reply #24 on: July 13, 2012, 10:56 PM »
my advice is.............................go to the gym and build some BIGGGGGGGGGGGGG ARMS  ;D.
have you tried sawing into it with an axesaw blade.
might weaken it enough to get it started  :-\.
