976288 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 11, 2026, 11:29 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Bolts on Pinchless
Author Topic: Bolts on Pinchless  (Read 2848 times)
Offline Devilock
Bolts on Pinchless
« on: July 16, 2012, 08:54 PM »
This...
Will not fit this...
Even though they're both 15mm...! What the f*ck is going on...?
Re: Bolts on Pinchless
« Reply #1 on: July 16, 2012, 08:55 PM »
is it 15mm AF not a standard 15mm ?? Just a guess
Offline Devilock
« Reply #2 on: July 16, 2012, 08:57 PM »
What the bleedin ell does that mean...??!!!  ???
« Reply #3 on: July 16, 2012, 09:05 PM »
AF means across the flats of the spanner. It really is just a guess though as ive never come across metric AF bolts, but that doesnt mean they dont exist
Offline HUTCHMAN
« Reply #4 on: July 16, 2012, 09:21 PM »
what doesn't fit..the internal of the socket onto the bolt or the outer of the socket into the crank arm?
bobbysam
« Reply #5 on: July 16, 2012, 09:26 PM »
Is it the outer diameter of the socket that is stoping it fitting into the crank arm? I had the same problem, had to grind down the socket, if you don't have the facilities to do this let me know, pretty sure mine is also 15mm, I'll post it to you as a loan.
Bobby
Offline Devilock
« Reply #6 on: July 16, 2012, 09:27 PM »
Well I must admit it doesn't insert very well but its the only 15mm socket I have. Can you get 15mm that are tapered? Has anyone got one that will fit...?!!  :(
Offline Devilock
« Reply #7 on: July 16, 2012, 09:30 PM »
Bobby
If you could post it that would be great, cheers!  :daumenhoch:
Surely there is something available to avoid grinding it down... ???
bobbysam
« Reply #8 on: July 16, 2012, 09:31 PM »
See my last reply
Offline diesel
« Reply #9 on: July 16, 2012, 09:35 PM »
Halfords do a slim range of sockets - I have one for this very purpose  :daumenhoch:
Offline Devilock
« Reply #10 on: July 16, 2012, 09:48 PM »
You wait ages for a bus then...........!!!  :D
Well ill take a trip to Halfords! Show me a pic of yours please if possible ...& the socket...!!!!  ;D
Offline oldtired
  • Dirty Old Man
« Reply #11 on: July 16, 2012, 10:14 PM »
will a proper crank puller tool not fit ?   they have 14 / 15mm  double ended socket and also a thread in puller for the arms :daumenhoch:
Frosty
« Reply #12 on: July 16, 2012, 10:35 PM »
As the above says, get a crank puller because you are likely going to need it to get the 400 arm off the tapered spindle anyway! Or you'll end up getting a hammer out, which may have been acceptable in the 80's but not on those cranks now :2funny:
Offline oldtired
  • Dirty Old Man
« Reply #13 on: July 16, 2012, 10:45 PM »
 :LolLolLolLol:      yup don't want to be hammering them off,       puller tool is one of those tools when you use one for the first time you think "why the fook didn't i buy one of these years ago"    :LolLolLolLol:
