976288 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 11, 2026, 03:43 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  DP Firebird fork damage.
Author Topic: DP Firebird fork damage.  (Read 7066 times)
rwleigh
« on: July 21, 2012, 11:36 AM »
Hi all,
Iv'e just aquired a DP Firebird GL Plus and in general it's in great condition.
The only problem with it is some damage to the top of the forks as can be seen below.
Now this won't be seen when the forks are in the frame but i'm just wondering what others would do with this, should i just leave it or should i atempt to improve it?
After a conversation last night with Steve "Firebird" Dobson he thought it may have been caused by some bearings escaping from the race and grinding round in the haed but on inspection inside the head there's no evidence of this as shown here.
So what do you think caused it and what would you do with it?
Cheers,
Richard.
Offline Robbo
Re: DP Firebird fork damage.
« Reply #1 on: July 21, 2012, 12:11 PM »
Looks like hammer damage.  :daumenhoch:
« Reply #2 on: July 21, 2012, 12:12 PM »
Strange as there all the same size  ???
bearing ?
hammer ?
i would say bearing caught - but frame may not be the one it was in ?
I would leave it as it won't affect it in any way  ;)
full pic of bike and frame number please  :)
cheers B
snapper
« Reply #3 on: July 21, 2012, 12:26 PM »
heres a tip ...............go to your local car auto parts store ..........ask for a stainless metal fibre bog .....
its as tough as they come in fact can with stand powder coaters oven temps of over 200 c
here is our 2 ....no1- pin hole filler ....no2 stainless patching ....both are 2 part
IT IS HIGHLY RECOMMENDED THAT THREADS AND NON  .-WORKING ZONES  ARE TO BE PROTECTED AND TAPED/ COVERED .....
rwleigh
« Reply #4 on: July 21, 2012, 12:27 PM »
cheers B
133
snapper
« Reply #5 on: July 21, 2012, 12:32 PM »
THATS A SWEET RIDE MATE .............taking a closer look .........i would also purchase emery paper hard cut 180 /240 grit .....if you run a strip over the area of paper and in a SHOE SHINE FASHION  over de-burring the pitts it would also help ..
caution .........threads ............nut holes etc non zones are to be protected ..... :)
rwleigh
« Reply #6 on: July 21, 2012, 12:35 PM »
That's what i first suspected, I'm considering a fluorescent green powder coat from SBD and i like the look of your DP. Any chance you could send me some photo's of it in the sun to see how bright it is? Most of the photo's of the fluorescent green DP's I've seen just don't quite look bright enough to me compared to the original BITD.
« Last Edit: July 21, 2012, 12:44 PM by rwleigh »
rwleigh
« Reply #7 on: July 21, 2012, 12:36 PM »
That's what i had in mind, just wanted to see what others thought first.
« Last Edit: July 21, 2012, 12:43 PM by rwleigh »
snapper
« Reply #8 on: July 21, 2012, 12:53 PM »
heres our list ..........only ...i hope that might help
ask your local guy powder as fluros are not often in powder larger works ........therefore not wise in powders box purchase ......here .... :)
snapper
« Reply #9 on: July 21, 2012, 12:57 PM »
i suggest highly ....................................note ...#.powder ........the make /name serial number of your find .............and that will ensure your treasure is powdered exactly that ... :)........................also in powder .................every damage item must be repaired as fluro /whites will make them eye sores .. :)
snapper
« Reply #10 on: July 21, 2012, 12:58 PM »
EVEN DROP-OUT RINGS .... ;)
Offline Robbo
« Reply #11 on: July 21, 2012, 01:19 PM »
Unfortunatley I dont have any pics of it outside, I built it and never used it.  ::)
rwleigh
« Reply #12 on: July 21, 2012, 01:24 PM »
Never mind Robbo, in your opinion does SBD's flo green look brighter to your eye than in the photo?
« Last Edit: July 21, 2012, 01:34 PM by rwleigh »
Offline Robbo
« Reply #13 on: July 21, 2012, 03:03 PM »
Yes it does, you need to order the powder from Rosey's in the states and Dan will do the magic.  :daumenhoch:
rwleigh
« Reply #14 on: July 21, 2012, 03:10 PM »
Any idea what went wrong with this one using Rosey's neon pink?
Nothing like the origonal dp pink on the bars.
Is it just down to the skill of the powder coater to get the right effect?
rwleigh
« Reply #15 on: July 21, 2012, 03:17 PM »
Now that's more like it, just want green instead of pink!  :)
« Reply #16 on: July 21, 2012, 03:24 PM »
you see that pink frame... yeah that one above ... I want it.
I'd even swap my complete 91 Sport for a GL Plus with Ladder bars ... probably.
Offline Robbo
« Reply #17 on: July 21, 2012, 03:25 PM »
The pink is hard to photograph, actually I think all neons are tbh.  :daumenhoch:
Ed, your getting as bad as me for wanting to build bikes you've already owned.... :LolLolLolLol:
