976299 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 25, 2026, 10:19 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Skyway Tuff 2
Author Topic: Skyway Tuff 2  (Read 2097 times)
bbmac
Skyway Tuff 2
« on: July 03, 2006, 06:35 PM »
How do you remove the rivets on Tuff 2  and what do you use to refit hubs
Offline BrianP
Re: Skyway Tuff 2
« Reply #1 on: July 03, 2006, 06:40 PM »
drill out the unrivetted end of the rivet (there are definitely posts on here explaining this in detail - came up a month or two ago)
I use M4 threaded stainless steel studding and M4 stainless steel nylock nuts on my rebuilds.
Bp.
bbmac
Re: Skyway Tuff 2
« Reply #2 on: July 03, 2006, 06:48 PM »
Thanks now i can make a start on bleaching and dying tuffs from a very pale yellow / white back to yellow
selfpreservation
Re: Skyway Tuff 2
« Reply #3 on: July 03, 2006, 07:06 PM »
cant you yus leave th alloy hubs in and grease them for protection see the how to section
Offline Nosnod
Re: Skyway Tuff 2
« Reply #4 on: July 03, 2006, 08:30 PM »
Don't remove the rivets if you don't have to!
I had a pair of yellows in neat bleach for about 6 days. Just plaster the metal bits in grease and they will be fine. If they go a bit blackish don't worry as it polishes out.
bbmac
Re: Skyway Tuff 2
« Reply #5 on: July 03, 2006, 08:39 PM »
one of the rear wheel rivets is missing so im going to totally refurb them ,
