976288 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 11, 2026, 01:08 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  cleaning a chain
Author Topic: cleaning a chain  (Read 2010 times)
Offline Gish
cleaning a chain
« on: July 27, 2012, 03:47 PM »
got a nice old izumi chain and its just full of gunk and shite, whats the best way to clean it  :-\
Ride it like its stolen
Offline Gish
Re: cleaning a chain
« Reply #1 on: July 27, 2012, 05:13 PM »
anyone  ???
bof
« Reply #2 on: July 27, 2012, 06:07 PM »
Wd 40 and a tooth brush.  Small wire brush if its not painted :)
Offline That Swan Guy
« Reply #3 on: July 27, 2012, 06:08 PM »
Similarly, soak in petrol then a scrub :daumenhoch:
M5AT
« Reply #4 on: July 27, 2012, 06:16 PM »
I soaked a manky one in neat fairy liquid, then poured boiling water over it & scrubbed it with a toothbrush.
most of the fooking paint came off!
Rodgy1970
« Reply #5 on: July 27, 2012, 06:31 PM »
Wash and dry out a 2L milk jug, add 300-500ml of diesel (red is cheap), insert chain shake like fook (chuck a few old bearings in), cut the top off to get it out, may need to give it a scrub with tootbrush and repeat.
Soak overnight in engine oil, hang up and the excess will run off.
Offline Munnyella
« Reply #6 on: July 27, 2012, 06:44 PM »
Dishwasher, hot program, then retire to the shed when the wife sees!
MM
« Reply #7 on: July 27, 2012, 08:19 PM »
Isopropyl alchohol will clean it up absolutely lovely.
« Reply #8 on: July 27, 2012, 08:49 PM »
White spirit  :daumenhoch:
GaryN
« Reply #9 on: July 27, 2012, 09:26 PM »
I've got a chain soaking in Jizer in a plastic container with a lid on it in the garage, every time I go in there I give it a shake.
Hopefully with a bit of work with a tooth or small scrubbing brush over the weekend and a wash down with boiling water and the job should be jobbed.
The amount of cr@p that has come out of it so far is astounding, but by the same token it is the largest bike chain I have ever seen (Sachs 415).
dan-dare
« Reply #10 on: July 27, 2012, 09:28 PM »
Offline kev-s
« Reply #11 on: July 27, 2012, 09:48 PM »
this is what i do with my £50 road bike chain once a month to clean out all the road grime and muck etc... so should be ok to do to a izumi chain :daumenhoch:
get a jug and drop your chain in it then pour in enough petrol to cover the chain (pertol per litre is cheaper than any bike specific chain cleaner)
leave overnight to really loosen all the grit and grime right within all of the links, pour away the petrol, take the chain out of the jug and wash all the grit and grime out of the jug
now pop the chain back in and add some more petrol and give it a good swirl around the chain to remove the last bits of grit and grime
now remove the chain and hang it up for a few hours to allow the petrol to evaporate
refit the chain to your bike and apply some dry lube to each link (finish line dry lube £2 for 4oz bottle)
the dry lube goes on wet and dries within minutes
the chain will run nice and smooth and wont get oil on you
been doing this for years and costs around £6 every 6 months :daumenhoch: :daumenhoch: :daumenhoch:
