976254 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 14, 2026, 02:09 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  1 3/8" rims
Author Topic: 1 3/8" rims  (Read 1611 times)
ammacopij72
1 3/8" rims
« on: August 07, 2012, 02:19 PM »
Always liked the skinny wheeled look bitd so I'm looking for advice on any issues with fitting these to a standard frame ('83 Kuwi Nova). I know the rim diameter is larger than 1.75/2.125 so will there be problems with the brakes?
Cheers all  :daumenhoch:
Pij
Re: 1 3/8" rims
« Reply #1 on: August 07, 2012, 02:31 PM »
You will need shorter reach brakes for sure.
Offline Andy68
Re: 1 3/8" rims
« Reply #2 on: August 07, 2012, 02:39 PM »
X2............As you say, rim diameter is larger than ya standard rims but rolling diameter will be more or less the same, 20''.  No doubt tho' you're gonna end up needing shorter reach calipers.   :daumenhoch:
« Last Edit: August 07, 2012, 02:58 PM by Andy68 »
Offline Gary72
Re: 1 3/8" rims
« Reply #3 on: August 07, 2012, 07:09 PM »
You might have brake bridge clearence issues.
ammacopij72
Re: 1 3/8" rims
« Reply #4 on: August 08, 2012, 01:46 PM »
Cheers lads,
Just scored a nice set of 1.5 Ukai's and comp3's off the 'bay so that should make life easier!  :D
Pij
Offline Andy68
Re: 1 3/8" rims
« Reply #5 on: August 08, 2012, 01:59 PM »
 :daumenhoch:  Sounds an easier option!!!
