976254 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 14, 2026, 02:09 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Bleach and OGK's
Author Topic: Bleach and OGK's  (Read 4753 times)
Offline CustardLips
Bleach and OGK's
« on: August 18, 2012, 11:30 PM »
What's the score with the above ! Can i bleach em' to clean em' or will the colour fade ?
Or would a blast in the dishwasher be favourite ?
« Last Edit: August 18, 2012, 11:57 PM by CustardLips »
"WWG1WGA"
Re: Bleach and OGK's
« Reply #1 on: August 19, 2012, 12:56 AM »
What colour are thay ?
got a picture ?
here is a old thread of mine
the gorden ramsay way of dying wheels
take 1 set of OGK's - slightly faded
wash
pick out any dirty bits missed
scrape off any brake marks
bleach
hot water
salt
dye
put in and leave for 24 hours - turning and stiring every so often
cover
take out and wash in cold water - then dry
now ready to serve - i mean ride - DONE
cheers B
« Last Edit: January 10, 2013, 11:17 PM by BENDYCAT ELEVENTEEN »
Offline CustardLips
« Reply #2 on: August 19, 2012, 07:10 AM »
Yellow !The colour is good. Just need a good clean up !  :daumenhoch:
« Last Edit: August 19, 2012, 09:45 AM by CustardLips »
"WWG1WGA"
« Reply #3 on: August 19, 2012, 10:00 AM »
a clean in the dish washer will be fine - just don't add any bleaching agents or any salt - they may loose a touch of colour so not too hot a wash (that is only for dying after)
a good wash should get in nearly all of the hair lines and clean them out  ;)
Offline CustardLips
« Reply #4 on: August 19, 2012, 11:09 AM »
Nice one Bendy, knew you'd come to the rescue.  :daumenhoch:
The Mag Wheel Master !  :coolsmiley:
"WWG1WGA"
« Reply #5 on: August 19, 2012, 12:27 PM »
 ;D don't know about that - more like i try it a let yer know what doesn't work when i mess up  ;D
Offline not johndub71
« Reply #6 on: August 19, 2012, 01:11 PM »
A guy on super scrimpers was cleaning outside patio furniture with a couple of finish dishwasher tablets in hot water and gave the plastic chairs a good scrub. Could be worth a go.
Facebook/Fr35Hair
Offline CustardLips
« Reply #7 on: August 19, 2012, 01:19 PM »
Been in the dishwasher with tesco's everyday value tab's. Come up a treat, just a bit of brake rub to remove now.
Going on a survivor/rider anyway so no need for perfection !  :daumenhoch:
"WWG1WGA"
Offline CustardLips
« Reply #8 on: August 19, 2012, 02:17 PM »
Bendycat, you don't happen to possess a couple of spare washer/cone nuts for these do you ?
Or know where I can get a spindle kit for one.
Cheers.  :daumenhoch:
"WWG1WGA"
« Reply #9 on: August 20, 2012, 10:55 AM »
Funny you should ask   ;D
Right i have been resto'ing some of my hubs with a rebuild kit that i have - i have got a load of hubs/axles in and i take them apart and clean them up, they can be used to rebuild most standard hubs.
I have rebuilt up sets of Alloy hubbed Skyway mags with the cup bearings holders (not sealed bearing hubs) - you can replace most cup race bearing holder type mags and spoked wheels - although some might not fit so you will have to check first.
you can replace the axle to a standard fit size nut that is on a 10mm axle.
so i can do you a 10mm axle - a caged bearing race -  cone nuts that go against the bearings - the washer nut that sits tight next the cone nut - a bobble washer - a outside nut.
here is what the kit looks like
So you get
2x axle in black - 138mm long 10mm wide - standard thread size (not skyway size, so won't fit skyway nuts on)
4x caged bearing race in silver- 24mm across - 6mm deep - strong and well made.
4x cone nuts in black with removable skirt/shield, just tap it off or move up and down for a better fit - 17mm across 14mm deep on cone nut - 24mm across 2mm deep on shield.
4x washer nut in silver - 16mm across - 3mm deep
4x bobble washer in silver (well what would you call it ?) 16mm across - 2mm deep
4x outer nut in silver - 15mm across - 14mm deep
If you want a kit it will do both wheels - but please check rear drop out size of axle, as some can be wide (you can use your own rear axle with this kit if you need to fit wider )
i can sell a single half kit for one wheel if needed
kits will not be broken up for sale of individual parts
price's are
£10 posted for a kit (this is for two wheels)
£5 posted for a half kit (for one wheel )
if i get loads of members wanting this item, it may take a little while to sort the first load out - i have work and other members mags to restore + need to sleep and eat at some point !
please post in here and then a pm - if i don't get both you will miss out
they may not fit all, that is why i have given sizes -  so please realize I'm not perfect, just trying to help
GT STYLE 8mm cut side axle rebuild kit ~ Limited numbers !
£8 single kit posted
129mm in length - 10mm axle with the GT fork 8mm cut sides - this allows the axle to slip in to the 8mm axle gap on GT forks and such like.
bearing cage  25mm across 6mm deep cone nuts 15mm across 11mm deep -  cone nut washer 15mm across 3 mm deep - washer with groves on one side 19mm across 2mm deep - out side nut 15mm across 10mm deep - can also surply loose bearings on these.
cheers B  ;)
Offline CustardLips
« Reply #10 on: August 22, 2012, 12:07 AM »
Can OGK's be converted to a coaster brake ?
"WWG1WGA"
« Reply #11 on: August 22, 2012, 12:19 AM »
don't know - did they ever have one ?
Offline CustardLips
« Reply #12 on: August 22, 2012, 09:57 PM »
I have no idea !
"WWG1WGA"
« Reply #13 on: August 22, 2012, 11:02 PM »
then we are both in the same boat of "no clues"  ;D
Offline CustardLips
« Reply #14 on: August 23, 2012, 07:39 AM »
Nice one mate, I'll be onto you for some spindles in the next week or two.  :daumenhoch:
"WWG1WGA"
« Reply #15 on: August 23, 2012, 10:34 AM »
 :daumenhoch: just pm when you need them  ;)
Offline MaD-RoK
« Reply #16 on: August 23, 2012, 10:37 AM »
These threads haunt me, could you do some fresh pictures Bendy?  :D
« Reply #17 on: August 23, 2012, 10:59 AM »
this picture haunts me  :crazy2:
Offline MaD-RoK
« Reply #18 on: August 23, 2012, 12:08 PM »
Whats haunting about a rad mofo on a beat earning cash for charity with other rad mofo's in London? You are strange at times Andy.  :LolLolLolLol: :LolLolLolLol: :LolLolLolLol:
Offline benno
« Reply #19 on: August 24, 2012, 08:53 PM »
yep i've got a coaster set  :daumenhoch:
It comes out of the ground!
