976254 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 14, 2026, 12:07 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Tuf Neck Ace stem problem solved
Author Topic: Tuf Neck Ace stem problem solved  (Read 1656 times)
Rob1
« on: August 26, 2012, 02:42 PM »
Has anyone else had this problem ? A Tuf Neck Ace stem with the big bolt installed ; the top cap won`t line up and I can`t get my bolts in . Looks like this :
I didn`t really want to take any material out of the top cap to get it to line up . So a bolt was made with a slightly smaller head and there it is , job done :
Picture showing slight difference in head size . I think the original was 15/16" , the new one is 7/8" . Stainless too so will polish up a treat !
Re: Tuf Neck Ace stem problem solved
« Reply #1 on: August 26, 2012, 02:51 PM »
well done!
wonder why it was like that in the firsy place.....  ???
« Reply #2 on: August 26, 2012, 03:11 PM »
top job and well sorted  :daumenhoch:
« Reply #3 on: August 31, 2012, 05:10 PM »
There it a distict possibilty that the bolt had been replaced at some point with a whitworth bolt instead of UNC hence the head being 2 big  :D The threads r very similar  ::)
Offline Waxintaxin
« Reply #4 on: August 31, 2012, 05:12 PM »
Or the top and bottom are from different stems !!
« Reply #5 on: August 31, 2012, 08:43 PM »
I concur I think thats a standard stem top that may have been modified 2 suit, and the cut out isn't big enough ?
