976254 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 13, 2026, 08:55 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  chain ring to freewheel sizing ?
Author Topic: chain ring to freewheel sizing ?  (Read 1411 times)
« on: September 03, 2012, 02:19 PM »
A 39 tooth chain ring - what size freewheel ?
i know you can have a fast start feel or  more pace with a bigger size
just wondered what size do what ?
cheers B  ;)
Re: chain ring to freewheel sizing ?
« Reply #1 on: September 03, 2012, 02:21 PM »
15?  :-\
Offline Jon The Bassist
« Reply #2 on: September 03, 2012, 02:37 PM »
On a 20" BMX you want a chainring to freewheel ratio of about 2.75, eg 44/16, 39/14 etc.
Anything that makes the ratio bigger gives more top speed.
Anything that makes the ratio smaller gives more acceleration.
« Reply #3 on: September 03, 2012, 03:02 PM »
so does a 14t fit on a normal hub or is it the double sided hub it needs ? ???
mattuknc
« Reply #4 on: September 03, 2012, 03:11 PM »
Yep, you'll need a flip flop hub or whatever they're called for a 14t.  :daumenhoch:
« Reply #5 on: September 04, 2012, 11:13 AM »
Yep, you need a flip-flop hub.
I run an Odyssey 13T freewheel on my Badlander as it's the smallest you can get for a 30mm metric side on a flip-flop which let's me run a 36T chainring on a 110mm BCD powerdisc. Any smaller will clip the chain and you will need a small 110mm BCD spider to avoid this which wasn't an option on a park bike.
