976244 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 08, 2026, 10:03 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  OA Bath
Author Topic: OA Bath  (Read 4268 times)
e5dcb
OA Bath
« on: September 30, 2012, 04:24 PM »
Is it normal for the water to turn cloudy? After a few hours. ?
Re: OA Bath
« Reply #1 on: September 30, 2012, 05:00 PM »
Yes
Cover it and leave it for 24 hours and then wash off with clean water.
e5dcb
Re: OA Bath
« Reply #2 on: September 30, 2012, 05:07 PM »
It's been in 3 hours just took the forks out and it wipes off ok. Not touched the rust yet no yellowing , so your saying leave it in for 24 and it still should wipe off ok. ?
Re: OA Bath
« Reply #3 on: September 30, 2012, 06:27 PM »
It takes a good 24 hours for it to work, the rust will eventually be replaced by a white residue that will wipe off and hey presto no rust.
e5dcb
Re: OA Bath
« Reply #4 on: September 30, 2012, 06:49 PM »
Ah yeah I know it takes that long but I've seen pics of a frame that's been stained by a white powder from a Oxylic acid bath.
http://www.ozbmx.com.au/index.php'showtopic=45816&st=20
Re: OA Bath
« Reply #5 on: September 30, 2012, 08:27 PM »
Looking at that thread I would imagine that there was a flaw in the nikel plating that the OA somehow managed to penetrate or that the guy used WD40 etc on the frame 1st.
I have never had any problems with 24 hours in OA, but with anything you take a chance when restoring things.
e5dcb
Re: OA Bath
« Reply #6 on: October 01, 2012, 08:18 PM »
Came out great fella :-)
Offline not johndub71
Re: OA Bath
« Reply #7 on: October 01, 2012, 08:33 PM »
Thats amazing!
Facebook/Fr35Hair
Re: OA Bath
« Reply #8 on: October 01, 2012, 09:03 PM »
Beauty of a result, top work.  :daumenhoch:
Re: OA Bath
« Reply #9 on: October 01, 2012, 09:04 PM »
fookin top result that  :4_17_5:
e5dcb
Re: OA Bath
« Reply #10 on: October 01, 2012, 09:25 PM »
Yeah well pleased with the result that's it just hosed off straight out the bath. No polish yet  :shocked:
Offline GavinDavis
Re: OA Bath
« Reply #11 on: October 01, 2012, 10:10 PM »
Thats a stunning result!!  Ive had some really good experiences with OA too.  How much are you adding to the water mixture?
e5dcb
Re: OA Bath
« Reply #12 on: October 01, 2012, 10:21 PM »
3 table spoons in a builders mixing /dog bath and about 28 hours.  :daumenhoch:
e5dcb
Re: OA Bath
« Reply #13 on: October 01, 2012, 10:42 PM »
Some better shots of the frame.
Anyone thinking about an Oxylic–Acid bath go for it if you haven't already.
Offline GavinDavis
Re: OA Bath
« Reply #14 on: October 01, 2012, 11:29 PM »
 :bondage:
Fair play! I use a really big tray that used to be the base of an old rabbit cage. It holds about 50 litres or so. I was under the impression that using more OA would work better so i added the best part of 250g to a hot water mix. The bits and bobs that i did worked a treat but almost not as good as yours. Maybe less is more with this stuff?
e5dcb
Re: OA Bath
« Reply #15 on: October 01, 2012, 11:41 PM »
I used the guide on the museum. But read a lot of threads where people have added too much the reaction has happened quicker and ended up staining and they then had to polish the hell out of the frame to remove the marks. I didn't use hot water either just straight out the tap.
Re: OA Bath
« Reply #16 on: October 02, 2012, 06:08 PM »
Result  :4_17_5:
Offline Pooch
  • funny you should say that..
Re: OA Bath
« Reply #17 on: October 02, 2012, 07:09 PM »
That's a great job :daumenhoch:
Griff loves BUM..
Re: OA Bath
« Reply #18 on: October 02, 2012, 08:00 PM »
Great results, where do you buy this Oxylic acid from, I've got something I need to do this to  :-X
e5dcb
Re: OA Bath
« Reply #21 on: October 02, 2012, 08:44 PM »
That will do I got the 1kg tub from that seller.
If you have the space I've read you can leave the bath full and re use it for up to a year without adding more acid.
Offline poolysheriff
Re: OA Bath
« Reply #22 on: October 02, 2012, 08:53 PM »
Bloody good stuff that  :4_17_5:
Offline GavinDavis
Re: OA Bath
« Reply #23 on: October 02, 2012, 11:02 PM »
Ah cool :) ...thats good to know.
