976244 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 08, 2026, 11:56 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Pott's mod?
Author Topic: Pott's mod?  (Read 1976 times)
Offline sparkysx
Pott's mod?
« on: November 05, 2012, 08:42 PM »
Can you run one on these calipers? are you able to swap the top and bottom fixings around?
cheers
Offline billstup
Re: Pott's mod?
« Reply #1 on: November 05, 2012, 08:44 PM »
Yep, I`ve altered some before  :daumenhoch:
Offline sparkysx
Re: Pott's mod?
« Reply #2 on: November 05, 2012, 08:53 PM »
how did you alter them, was it easy enough?
cheers
Offline billstup
Re: Pott's mod?
« Reply #3 on: November 05, 2012, 10:38 PM »
cheers
Just unbolt  the 2 bits that unbolt , swap them over and refit them upside down   :daumenhoch:
Re: Pott's mod?
« Reply #4 on: November 05, 2012, 10:58 PM »
 ;D
so it's not riveted on, the bottom lever, i take it !
Offline sparkysx
Re: Pott's mod?
« Reply #5 on: November 05, 2012, 11:36 PM »
It certainly looks riveted on.
Offline wildon
Re: Pott's mod?
« Reply #6 on: November 05, 2012, 11:58 PM »
Yes it's riveted. You need to grind that one of, buy a front quick release from pork chop and have it pressed on. You'll need to change the adjuster for a front too.. If you want to do it properly that is
Offline not johndub71
Re: Pott's mod?
« Reply #7 on: November 06, 2012, 10:37 AM »
I drilled mine off.
Facebook/Fr35Hair
Offline john4130
Re: Pott's mod?
« Reply #8 on: November 06, 2012, 05:35 PM »
leave the quick release on and stick a normal adjuster through it, then just stick a pinch bolt where the top adjuster was.
