976244 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 08, 2026, 10:16 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  BAR EXTENDERS - Do they exist ?
Author Topic: BAR EXTENDERS - Do they exist ?  (Read 2671 times)
Offline CustardLips
« on: November 06, 2012, 11:34 PM »
Can you get screw in/screw out type thingy's to extend bars or do they need to pay a visit to a welder type gentleman ?  :crazy2:
"WWG1WGA"
Re: BAR EXTENDERS - Do they exist ?
« Reply #1 on: November 07, 2012, 08:00 AM »
Nick - YGPM mate.
You need to speak to Jedi Welding Master Phil "Sawzall". Problem solved :yahoo_silent: :daumenhoch:
thecaptain
« Reply #2 on: November 07, 2012, 08:57 AM »
Nick - YGPM mate.
im after the same thing but pm'ed him last week and had no reply since, is he away or busy or something?
HEYWOOD BMX
Offline GavinDavis
Offline CustardLips
« Reply #5 on: November 07, 2012, 09:32 AM »
http://deluxebmx.com/product/bar-end-extenders/
Nice one James.  :daumenhoch:
Are they extenders  ? They look like end caps !
"WWG1WGA"
HEYWOOD BMX
« Reply #6 on: November 07, 2012, 12:15 PM »
 :) Definately extenders-the bar caps are different.I sold/fitted a set last week.
Offline CustardLips
« Reply #7 on: November 07, 2012, 01:39 PM »
Old school grips wouldn't fit over em' though would they ?  ???
Or am I just being thick !  :idiot2:
« Last Edit: November 07, 2012, 01:47 PM by CustardLips »
"WWG1WGA"
Offline Glynnyboy
« Reply #8 on: November 07, 2012, 02:23 PM »
I must be too then.  :)
It looks like a 1" extender with the added end flared to do the end cap job too.
With that end cap flare for new school grips it doesn't look like you would be able to get a set of os grips over because that bit is wider than the grip.
Offline not johndub71
« Reply #9 on: November 07, 2012, 06:08 PM »
Dare I say you could always cut a hole in the end of the grip    :daumenhoch:
Facebook/Fr35Hair
Offline Glynnyboy
« Reply #10 on: November 09, 2012, 10:51 PM »
 :shocked: cutting holes in os grips ?
Offline CustardLips
« Reply #11 on: November 09, 2012, 11:50 PM »
Yeah, i agree. Big No No !  :idiot2:
"WWG1WGA"
Offline GavinDavis
« Reply #12 on: November 10, 2012, 11:17 AM »
If your using o/s grips then you could either cut the end flange off by hand, or turn it down in a lathe.  Either way would work as the grubb screw is still visible to be able to clamp it to the inside of the bars :)
When you put your o/s grips over the top of the extensions you wouldnt be able to tell any difference compared to the end of a normal bar :)
Job done....Slight bit of a modification to the extensions but it would definitely work.
gib66
« Reply #13 on: November 12, 2012, 04:48 PM »
all i need now is these being 2 inch either side instead of inch
Offline GavinDavis
« Reply #14 on: November 12, 2012, 07:58 PM »
What bars are you using?  Are they already cut cos you could always source the original size ones?  Or....if all else fails....bring on the welder :)
