BAR EXTENDERS - Do they exist ?
Glynnyboy:
:shocked: cutting holes in os grips ?
CustardLips:
--- Quote from: glynnyboy on November 09, 2012, 10:51 PM --- :shocked: cutting holes in os grips ?
--- End quote ---
Yeah, i agree. Big No No ! :idiot2:
GavinDavis:
If your using o/s grips then you could either cut the end flange off by hand, or turn it down in a lathe. Either way would work as the grubb screw is still visible to be able to clamp it to the inside of the bars :)
When you put your o/s grips over the top of the extensions you wouldnt be able to tell any difference compared to the end of a normal bar :)
Job done....Slight bit of a modification to the extensions but it would definitely work.
gib66:
all i need now is these being 2 inch either side instead of inch
GavinDavis:
What bars are you using? Are they already cut cos you could always source the original size ones? Or....if all else fails....bring on the welder :)
Navigation
[0] Message Index
[*] Previous page
Go to full version
