976244 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 08, 2026, 11:08 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Crazy 95's
Author Topic: Crazy 95's  (Read 3347 times)
Offline GavinDavis
Crazy 95's
« on: November 08, 2012, 09:54 PM »
Hi Guys,
Has anyone on here ever built any Peregrine Crazy 95's?
Im really considering making my own out of a 48 spoke rim by drilling an extra hole between each existing one....Although initially i wont be butchering a pair of peregrines (just incase it goes a bit pete tong)  :LolLolLolLol:
Has anyone got any photos of their builds and/or any info on the best hubs to use? I know im going to have to work out the pcd for the second row on a pretty high flange 48 so info would be ace :)
Cheers boyo's  :LolLolLolLol:
Re: Crazy 95's
« Reply #1 on: November 08, 2012, 10:00 PM »
if you drill them wrong the chrome will lift off in small chunks.
Offline GavinDavis
Re: Crazy 95's
« Reply #2 on: November 08, 2012, 10:08 PM »
I was thinking of going for a decent none chrome rim, drilling the holes and then having them anno'd or polished to save any chrome problems.
I take it the holes on the rim cant be offset to one another and have to therefore be inline and radial laced?  What hubs would be the best donors for the operation?   ;D
......Unless of course you wanna do me a deal on a certain set  ;)
stillriding
Re: Crazy 95's
« Reply #3 on: November 09, 2012, 01:57 PM »
I've a set of 95 Araya's in chrome
Does this help ?
Offline GavinDavis
Re: Crazy 95's
« Reply #4 on: November 09, 2012, 04:06 PM »
They look awesome!!  I take it they are Peregrine hubs?  Did you drill out a pair of 48's?  :)
Re: Crazy 95's
« Reply #5 on: November 09, 2012, 04:10 PM »
the old ones are suzue hubs but the same hub basically
you could buy them off the shelf years back.
Offline GavinDavis
Re: Crazy 95's
« Reply #6 on: November 09, 2012, 04:13 PM »
Are they Suzue 48 hubs with an additional ring of holes drilled?
Re: Crazy 95's
« Reply #7 on: November 09, 2012, 04:17 PM »
yes the hole is between 2 but further away  and regular 48h
remember not to drill 1 as the valve is in the way of having 96h
or youll have 1 hole on your hub with no spoke in it.
Offline GavinDavis
Re: Crazy 95's
« Reply #8 on: November 09, 2012, 04:26 PM »
Cheers for advice Dan :) ...Just need to find some hubs then now :)
Re: Crazy 95's
« Reply #9 on: November 09, 2012, 04:31 PM »
i have all the howto images you require.
Offline GavinDavis
Re: Crazy 95's
« Reply #10 on: November 09, 2012, 05:48 PM »
Ah that would be brilliant if you wouldnt mind emailing them to me?  Ill send you a PM over in a sec :)
Re: Crazy 95's
« Reply #11 on: November 09, 2012, 07:30 PM »
will dig the pics out   :daumenhoch:
Re: Crazy 95's
« Reply #12 on: November 09, 2012, 07:41 PM »
post em up here and we can make it a sticky  :daumenhoch:
Re: Crazy 95's
« Reply #13 on: November 09, 2012, 07:56 PM »
will do photobucket keeps freezing..
Offline GavinDavis
Re: Crazy 95's
« Reply #14 on: November 09, 2012, 08:03 PM »
Good idea Ed :) ....Im looking forward to doing this now :)
Offline oldtired
  • Dirty Old Man
Re: Crazy 95's
« Reply #15 on: November 10, 2012, 12:12 AM »
looking forward to seeing it done  :daumenhoch:     not since the mid 90's has such tinkering been considered  :daumenhoch: :LolLolLolLol:
do you gain any strength by doing this to a 48,  i thought that a well built 48 hole double skin rim  was effectively a solid wheel any how , or is it used for single skin rims?     wouldn't a rework or rather copy of the Truck conversion be easier to achieve ..................   mmmmmmmmmmmmm     right spanners  out  :LolLolLolLol:
Re: Crazy 95's
« Reply #16 on: November 10, 2012, 12:33 AM »
 :shocked:
i struggle to lace a 48 up  :crazy2:
Offline Discostu
  • Two's Company
Re: Crazy 95's
« Reply #17 on: November 10, 2012, 07:53 AM »
Mid 90's??  These were out in 1990. ;)
Offline kev-s
Re: Crazy 95's
« Reply #18 on: November 10, 2012, 08:05 AM »
billys sold them in 1992
they were called manly 95's in the uk
sealed version cost £269 and the unsealed version cost £245
they also did manly 71's for £189
Re: Crazy 95's
« Reply #19 on: November 10, 2012, 12:21 PM »
arr my local store back then,spent many hours in there,its moved 3 times since.
