How do I remove sealed bearings from a bottom bracket?
selfpreservation:
so how did you do it
hooga1975:
--- Quote from: selfpreservation on July 13, 2006, 11:25 PM ---so how did you do it
--- End quote ---
I used the hammer and screw driver technique, and gave them a good old whack!
FuNMoNsTeR:
For future reference:
You can cut out some rubber discs from some thick rubber sheet and place these inside the bb shell covering/protecting the bearing race/cup to be removed before you whack it ;)
Next weeks top tip:
How to remove those pesky boxer stains when you have followed thru trying to remove rusty pedals.
selfpreservation:
--- Quote from: hooga75 on July 14, 2006, 03:12 PM ---
--- End quote ---
--- End quote ---
sorry for being blonde but what precisley did you do as i may be changing frames soon(fingers crossed)
hooga1975:
I slid the one piece cranks through as far as I could. I the poked a long thin screw drive into the gap in the bottom bracket and gently tapped round the bearing until it popped out. It was easier than I thought it would be.
Navigation
[0] Message Index
[*] Previous page
Go to full version
