976243 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 08, 2026, 04:29 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  how to shinyside rims ???
Author Topic: how to shinyside rims ???  (Read 1446 times)
Offline Gizmo
« on: November 24, 2012, 03:30 PM »
looking at shinysiding some rims i got,
know i gota start with course to fine but what is
the correct process ? & what tools will i need
Thanks in advance :)
Re: how to shinyside rims ???
« Reply #1 on: November 24, 2012, 03:34 PM »
Orbital palm sander to start then lots of elbow grease with wet or dry is the usual method  :daumenhoch:
Offline GavinDavis
« Reply #2 on: November 24, 2012, 03:42 PM »
I did some a few weeks back now....do you mean you just want to do the sides?  I did both of the rims completely.
Started by buying the ovenpride kit from the supermarket (the one that includes the bag).  Put the in the bag with the solution and waited for around 15mins....this will strip the anno.  The finish then was pretty damn good so I didnt bother with any sanding.  Just got an alloy polishing kit of ebay for around £10 and set about them using both compounds.
It took a few hours in total but the finish was great.  I didnt want them to be mirror finish....Just a more subtle polished look.
I then did a stem with a bit more effort to get a better finish:
Offline Gizmo
« Reply #3 on: November 24, 2012, 03:47 PM »
just want to do the sides of rim , have you
Got a link to the polishing kit on the bay please
Offline GavinDavis
« Reply #4 on: November 24, 2012, 06:25 PM »
This is the kit that I bought....Should pretty much last you forever to be fair, unless youre planning on polishing everything in sight  :LolLolLolLol:
http://www.ebay.co.uk/itm/Aluminium-Metal-Polishing-Kit-14pc-For-Aluminium-Alloys-Brass-Copper-NFKF-0001-/300786229396?pt=LH_DefaultDomain_3&hash=item460841a094
Offline garran
« Reply #5 on: November 24, 2012, 06:42 PM »
back in the day i used duraglit wading to polish
Offline Gizmo
« Reply #6 on: November 24, 2012, 07:45 PM »
Thanks for tips guys :)
Ps that stem & wheels came up well
« Reply #7 on: November 25, 2012, 10:03 PM »
i normally put the wheel in an old pair of forks i keep and then in my vice.
dremmel out or the drill with a sanding wheel on and away you go.
loads easier to do the wheels this way than trying to hold em.
