976243 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 08, 2026, 01:50 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Welcome to'FOGS DIY ANODIZING'.......50% successful. NEW PICS.....
Author Topic: Welcome to'FOGS DIY ANODIZING'.......50% successful. NEW PICS.....  (Read 10304 times)
Offline adenough
  • Buzz Killington...
Right, thought id have a go at home anodising, im really pleased with the resutls considering its my first attempt, but i made a stupid error :LolLolLolLol:  ill let the pics talk:
levers as bought, then stripped,
then the set up equipment,
sulphuric acid and distilled water, lead cathode and ally wire to make the lever the anode,
left in the solution fizzing away for about 3 fags ( 30 mins), then remove and put into a tub of distilled water (from the condeser tumble dryer thing)
heated up some dylon mix in the nuke, let cool to about 50 degrees C,
then placed the lever into the dye for about 20 mins (this is when i realised what id done wrong)
now you have to seal the dye into the alloy by immersing the part into boiling distilled water for about 30 mins,
and hey presto, a loverly anodised tech 3, well nearly!! im personally amazed at the result!! but as you can see, i didnt connect the body of the lever properly.
your thoughts please........................
 :daumenhoch: :daumenhoch: :daumenhoch:
« Last Edit: December 08, 2012, 02:05 PM by adenough »
Offline threaders
Re: Welcome to'FOGS DIY ANODIZING'.......50% successful......pic heavy...
« Reply #1 on: November 25, 2012, 04:27 PM »
Looks great for a first effort and haven't seen anyone else try it before :daumenhoch: Set up looks complicated though. What sort of price are we talking for the gear used? ;)
« Reply #2 on: November 25, 2012, 04:29 PM »
Cant beat a bit of home brew  :daumenhoch:
Looks good for a first effort and i'm sure it would get better with practice.  :4_17_5:
Offline adenough
« Reply #3 on: November 25, 2012, 04:31 PM »
not much, more time than anything :daumenhoch:,  power supply, connectors (which i had to needle file to fit) croc clips, tubs etc, probs around £25, then youve gotta get caustic sosa, acid, lead, etc, cant really put a price on it as i scrounged some of the bits  :daumenhoch:
Offline HARORIDER
« Reply #4 on: November 25, 2012, 04:40 PM »
excellent effort  :daumenhoch: if you had polished the lever first the results would have been even better  :daumenhoch:
« Reply #5 on: November 25, 2012, 04:50 PM »
as above, hats off to ya  :daumenhoch:
Offline adenough
« Reply #6 on: November 25, 2012, 04:51 PM »
agreed, live n learn  :LolLolLolLol:
Offline SteveG
« Reply #7 on: November 25, 2012, 05:04 PM »
I Like this, I can refurb parts but they all end up silver ! Are you going to try some other colours ?
Offline bobbbbsy
« Reply #8 on: November 25, 2012, 05:05 PM »
cool story bro !
Offline adenough
« Reply #9 on: November 25, 2012, 05:07 PM »
ive got a green dye, might try an old chain ring or summat  :daumenhoch:
ratty67vw
« Reply #10 on: November 25, 2012, 05:10 PM »
cool propper DIY resto work looks good for your first try. look forward to seeing your next diy job  :daumenhoch:
« Reply #11 on: November 25, 2012, 05:38 PM »
Not a bad finish at all and if you enjoy that sort of thing then all the better.  :daumenhoch: Personally I'd rather take my bits to the anodisers and let them do what they know best. I got a mini Pro Neck stem striped and re annoed blue and a set of 7x rims annoed red then shinesided all for only £50.
« Reply #12 on: November 25, 2012, 06:12 PM »
nice1..why do you use dye? is that all anno is? great 1st effort  :daumenhoch:
Offline adenough
« Reply #13 on: November 25, 2012, 06:14 PM »
yep, thats all it is!!
« Reply #14 on: November 25, 2012, 06:32 PM »
its ok paying people to do things for you but you cant beat restoring something yourself  :daumenhoch:.
all you end up doing otherwise is bolting new parts on a frame and i cant really see the fun in that as you can build a bike in 30 mins if you take your time  ;D.
good effort rog  :)
Offline adenough
« Reply #15 on: November 25, 2012, 06:39 PM »
good effort rog  :)
ozone
« Reply #16 on: November 25, 2012, 07:11 PM »
good effort rog  :)
+1  Some hobby this would be if everyone just waved their cheque-book every time something needed doing.  This section would be very quiet for a start.   :uglystupid2:
Looking forward to the next installment when you anodise a polished component.   :daumenhoch:
b45t4rd
« Reply #17 on: November 25, 2012, 07:16 PM »
Fair play for trying something different, let us know how you get on.  :)
Offline adenough
« Reply #18 on: November 25, 2012, 07:28 PM »
will do deffo,I've got another tech 3 and my seat clamp plus my stem top  :daumenhoch:
« Reply #19 on: November 25, 2012, 07:38 PM »
Brilliant work  ;) came out real good  8) As I understand it the more u polish it before , the better shiny finish u get  :daumenhoch:
rad_pitt
« Reply #20 on: November 25, 2012, 07:46 PM »
Brilliant stuff mate. Looking forward to seeing the next batch  :daumenhoch:
deeman
« Reply #22 on: November 27, 2012, 10:30 AM »
Great stuff Roger,it will be interesting to see a polished component done-i reckon it will be spot on.It will also be interesting to see how different colours work.I reckon you could have a queue of people wanting this done!Keep the post updated as you do more! :daumenhoch:
« Reply #23 on: November 27, 2012, 10:39 AM »
Brilliant Rog. Got a couple of pots of Madonna Blue dylon I can send you along with some stripped & polished parts to try.......  ::)
« Reply #24 on: November 27, 2012, 10:44 AM »
Good on you for giving it a go  :daumenhoch: Bit of fine tuning and you'll be in business   :D
Spot on Dordy  :daumenhoch:
