976243 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 07, 2026, 10:56 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  BLACK SPRAY FOR Z RIM LOGOS
Author Topic: BLACK SPRAY FOR Z RIM LOGOS  (Read 4668 times)
« on: December 08, 2012, 04:51 PM »
Does anybody know what spray to use when spraying the Z RIM stencils onto the rims. Can you use any spray or does it have to be a special spray paint for plastic surfaces?
Thanks
Adam
Offline sawzall
Re: BLACK SPRAY FOR Z RIM LOGOS
« Reply #1 on: December 08, 2012, 04:57 PM »
i would use a light dusting of a good all plastics primer then a couple of light coats of a satin black :daumenhoch:
« Reply #2 on: December 08, 2012, 06:10 PM »
i'd just straight on with the satin aerosol black,  if you use grey primer first then go staight over the top with black without moving the stencil an outline of the primer under the black will be seen....
Offline Discostu
  • Two's Company
« Reply #3 on: December 08, 2012, 06:16 PM »
Plasticote would probably be the best.  :daumenhoch:
Offline sawzall
« Reply #4 on: December 08, 2012, 06:44 PM »
not if you use a clear plastic primer
« Reply #5 on: December 08, 2012, 08:30 PM »
 :daumenhoch: :daumenhoch:
good thinking batman!
« Reply #6 on: December 08, 2012, 10:33 PM »
Thanks for your advice fellas.  :daumenhoch:
jolly
« Reply #7 on: December 09, 2012, 03:09 PM »
you have to use a special paint for it that sticks straight on to plastic i know because i make paint for a living and if you put brakes on itll still wear off though because id have thought the originals would have been screen printed on
  • Andy
« Reply #8 on: December 09, 2012, 06:30 PM »
So does anyone know if there's a particular plastic paint that can be used without it rubbing off in 2 minutes?
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« Reply #9 on: December 09, 2012, 11:43 PM »
I got some rub ons from Retrospect - look fine to me and way less hassle, you can apply them indoors whilst watching the TV or eating a sandwich, combing your hair - you name it  :daumenhoch:
trickydeno
« Reply #10 on: December 09, 2012, 11:56 PM »
Ad I'm assuming your not gonna ride the bike once the wheels are fitted. In which case just use satin Matt black mate,I used it for some I did a while back and they were fine for show use  :)
  • Andy
« Reply #11 on: December 10, 2012, 01:32 PM »
I've just got some rub ons from ebay in white. I think foot braking will be the preferred method of stopping then to prevent them coming off
Offline wildon
« Reply #12 on: December 10, 2012, 01:54 PM »
i got rub ons from Del  :daumenhoch:
ozone
« Reply #13 on: December 10, 2012, 02:19 PM »
You might as well fit a coaster hub or see Kappy for a disc conversion.  :coolsmiley:
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« Reply #14 on: December 10, 2012, 02:54 PM »
Thats 3 votes for rub ons, eBay seller is Retrospect or use Del, they really do look sweet  :daumenhoch:
« Reply #15 on: December 10, 2012, 09:39 PM »
Chris - the trouble is i'm doing Adam's Z rims - complete retso on them and they need spray decals - have done the stick on's before, they work but this needs the stencil type  ;)
so the out come is what spray to use ?  ???
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« Reply #16 on: December 10, 2012, 10:16 PM »
Ah, well that I did not know B.   ;)
Shame the paint fella above "Jolly" hasn't followed up - if he makes paint for a living then he should know, maybe send him a PM?  ???
« Reply #17 on: December 10, 2012, 10:17 PM »
I've taken Phil Sawzalls advice and ordered some clear plastic primer which I'll post to you as soon as it gets to me Bendy.
Which satin black paint do I order though?
« Reply #18 on: December 10, 2012, 10:21 PM »
order satin black paint mate  :daumenhoch:
« Reply #19 on: December 11, 2012, 07:35 AM »
From where though, Dulux or what?
Do I get spray or a tin of paint?
« Reply #20 on: December 11, 2012, 11:07 AM »
spray - plastakote !
ozone
« Reply #21 on: December 11, 2012, 11:34 AM »
Is Plastikote era-correct though?    ;D
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« Reply #22 on: December 14, 2012, 04:53 PM »
Get a pic up B - lets see how you got on?  ???
