976243 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 08, 2026, 12:53 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  SHIMANO DX Spindles............
Author Topic: SHIMANO DX Spindles............  (Read 8752 times)
Offline adenough
  • Buzz Killington...
« on: December 08, 2012, 05:36 PM »
mine are 1/2 inch, was wondering if any generic spindles would fit as i now need 9/16? such as from Victors etc?  advice appreciated  :daumenhoch:
Offline Discostu
  • Two's Company
Re: SHIMANO DX Spindles............
« Reply #1 on: December 08, 2012, 05:40 PM »
Buy the black halfords pedals that are in the dx style. They are around £13 and are a straight swap.  :daumenhoch:
Offline adenough
« Reply #2 on: December 08, 2012, 05:42 PM »
Bingo, Thanks,  :daumenhoch:
Offline adenough
Offline Discostu
  • Two's Company
« Reply #4 on: December 08, 2012, 05:57 PM »
Yes they are the ones.  :daumenhoch:
We should make this a sticky. I've lost count the amount of times I have given out this information.  :LolLolLolLol:
Offline adenough
« Reply #5 on: December 08, 2012, 05:58 PM »
 :LolLolLolLol: :LolLolLolLol:
Offline GavinDavis
« Reply #6 on: December 08, 2012, 06:20 PM »
Bit of a long shot but I dont suppose this trick would work for Peregrine platforms would it Stu?  I was thinking of making some you see  :daumenhoch:
Offline Discostu
  • Two's Company
« Reply #7 on: December 08, 2012, 06:23 PM »
Take yours out and measure them. Sketch a pic of the shape and the measurements. Then we can have a look for spindles that are similar.  :daumenhoch:
Offline Discostu
  • Two's Company
« Reply #8 on: December 08, 2012, 06:25 PM »
You can also buy inserts for cranks that convert 9 1/6" to 1/2"
But I have never used them.  :daumenhoch:
Offline adenough
« Reply #9 on: December 08, 2012, 06:28 PM »
similar to a helicoil?
Offline GavinDavis
« Reply #10 on: December 08, 2012, 06:34 PM »
They havnt arrived yet  ;D .....Forward planning  ;)
Bought some Nos ones off a fellow Radster in France, he sent them out yesterday so they wont be long ....Woohoo!!
Offline GavinDavis
« Reply #11 on: December 08, 2012, 06:37 PM »
Interesting!!!!  Can you get a link up Stu?
Offline Discostu
  • Two's Company
« Reply #12 on: December 08, 2012, 06:48 PM »
I found some ages ago on a web site.  Fook knows where. I will have a search.  :daumenhoch:
Offline GavinDavis
« Reply #13 on: December 08, 2012, 06:53 PM »
Top man!  Would be a nice easy bit of kit for quite a few Radsters if it worked well  :daumenhoch:
Offline Dannywhac
  • return of the whac
« Reply #14 on: December 08, 2012, 06:57 PM »
For Perry's they'll work - you do need to trim off (with a Dremel) the last three threads on the new axles to get them to fit though. Done it a load of times :)
Offline Discostu
  • Two's Company
« Reply #15 on: December 08, 2012, 06:58 PM »
http://sheldonbrown.com/harris/pedals.html
I'm not sure if these were the ones I found before.  :daumenhoch:
As you can see they ain't cheap.
Offline GavinDavis
« Reply #16 on: December 08, 2012, 07:12 PM »
Nice one Dan  :) .....Look to be a cheaper alternative then to making a new set :)
Ed, if your reading....  ;)  :daumenhoch:
Offline GavinDavis
« Reply #17 on: December 08, 2012, 07:17 PM »
Ah cheers for the link Stu :)
It looks as though the final thread is 1/2" to fit an OPC....ultimately allowing you to use a 9/16th on an OPC.....really nice idea if they'd done it the other way round, although i guess it would extend the pedals from the crank arms quite a bit by the look of it.
Offline adenough
« Reply #19 on: December 08, 2012, 07:28 PM »
lots of thread tape  :LolLolLolLol:
Offline Discostu
  • Two's Company
« Reply #20 on: December 08, 2012, 08:59 PM »
http://www.ebay.co.uk/itm/JIC-female-Swivel-x-Bsp-male-Adaptor-9-16-18-x-1-2-6-/160919416197?pt=LH_DefaultDomain_3&hash=item25778b6d85
The thread on that is bsp. Ie British standard piping!!  Not the same as your cranks or pedals. Besides one side is left hand threaded.  ;D
Offline adenough
« Reply #21 on: December 08, 2012, 09:27 PM »
bsp, i remember that bugger of a thread, one of the hoses went on my lancia delta years ago, had a nightmare tryin to find the right bit! :daumenhoch:
Offline kev-s
« Reply #22 on: December 08, 2012, 11:10 PM »
the halfords fpd alloy platform pedal as posted above are a straight swap inc all the bearing cups, cones, lock nuts, bearings etc... the whole hardware fits into the dx body :daumenhoch:
if you want adaptors to convert 1/2 to 9/16th then asda is your best/easiest place, get some free pedals too :LolLolLolLol:
http://direct.asda.com/Bell-Universal-Bike-Pedal/000909255,default,pd.html?utm_source=ggle-shop&utm_medium=css&utm_term=000909255&utm_content=Other%20Bicycle%20Accessories&utm_campaign=ad&cm_mmc=ad-css-_-ggle-shop-_-Other%20Bicycle%20Accessories-_-000909255&istCompanyId=71f4ae42-94c5-4821-aa58-05eff6da2486&istItemId=mpitilrl&istBid=t
Offline adenough
« Reply #23 on: December 08, 2012, 11:16 PM »
there cool >:D
ozone
« Reply #24 on: December 09, 2012, 12:28 PM »
Perfect for bow-legged people them.   :D
