BMX General > BMX Chat
Crank removal tool for 3 piece cranks? (PIC ADDED) Please Look!
<< < (7/7)
Betty:
Looks like Danny's beat me to it with how they go together but i've took some pics to help if you wanna see  :)
An idiots guide so to speak  ;D
BMX1973:
Yes please, any help appreciated  :)
--- Quote from: Betty on December 18, 2012, 09:44 PM ---Looks like Danny's beat me to it with how they go together but i've took some pics to help if you wanna see  :)
--- End quote ---
Betty:
Here we go then  :daumenhoch:
An idiots guide to removing profile or similar cranks
Loosen the back wheel and get the chain out the way, i haven't but you'll get the idea
Hammer and a profile removal/installation tool or if you don't have one a 1/4" socket set extension bar, and old one is a good idea, like mine the ends will mushroom after a few years bb removal  ;D
Assuming your cranks/bb look something like this, remove the non drive side axle bolt and washer, if you want to remove the drive side arm and sprocket from the axle loosen the bolts a touch while they're still on the bike to make em easier to remove once the cranks are out, for bb replacement or swapping cranks from bike to bike just the non drive side will do  :daumenhoch:
Removal tool screws into the axle then you whack the end of the tool pushing the axle out of the drive side
Or if you don't have a removal tool the socket extension bar will do the same job
This end
Place here, and whack it again pushing the axle toward the drive side  :daumenhoch:
With profile cranks the axle bolts hold the whole thing together, bb cups should sit slightly proud of the bb shell like this
Before you fit a bb put the bearings/cups on an axle with the tube spacer and hold em up to the bb shell to check the tube spacer is long enough if it's too short the cranks won't spin freely, saves the ball ache of finding out when you fit the cranks and tighten everything up  >:(
Here's the whole axle/bb as Danny pictured but with the cone spacers, wider one goes on the non drive side  :daumenhoch:
To remove the bb use the socket set extension bar to lever the tube spacer out of the way and give the bearing cups a good whacking till they pop out, they do end up covered in whack marks on the back
I know they're an odd pair of bearings but they were the first 2 i found in my box of shite  ;D
Hope this has been some help  :daumenhoch:
Dannywhac:
Oh there's always one that has to go one better eh Betty  :yahoo_silent:
Betty:
I was bored Danny  :LolLolLolLol:
Navigation
[0] Message Index
[*] Previous page
Go to full version
