976242 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 07, 2026, 05:05 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Freewheel advice
Author Topic: Freewheel advice  (Read 6116 times)
Online CustardLips
Freewheel advice
« on: December 30, 2012, 02:39 PM »
Seen a thread a while back about this but can't find it !
Got a freewheel that needs re-greasing and seem to remember a thread about soaking it in petrol/diesel !
Is this right and which do i use ?  :)
"WWG1WGA"
Offline Dannywhac
  • return of the whac
Re: Freewheel advice
« Reply #1 on: December 30, 2012, 02:43 PM »
Soak it in petrol fella - when you've taken it out leave it for a bit so the petty can evaporate then use some Finish Line Wet Lube (oo-er etc) to re-grease.
Or take it apart and clean it, it's easy but there's a fook load of bearings so do it over a tub or summit to catch 'em.
Offline bobbbbsy
« Reply #2 on: December 30, 2012, 03:15 PM »
bin it !  :daumenhoch:
pkripster
« Reply #3 on: December 30, 2012, 03:29 PM »
Bin it ya tight sod u buy nos shimano 333 for just over a tenner on bay
Online CustardLips
« Reply #4 on: December 30, 2012, 03:59 PM »
No shimano 333's on ebay, besides it's a suntour which is in good nick, just needs a bit of lube.
Only for my lad's bike so don't need to be going overboard forking out £££'s.  ;)
"WWG1WGA"
Offline kev-s
« Reply #5 on: December 30, 2012, 05:01 PM »
as danny said petrol then wet lube or strip it and clean it
we throw away far to much stuff that can be easily fixed :daumenhoch:
« Reply #6 on: December 30, 2012, 05:20 PM »
Kev, I agree..but for £7 you can get a new one. If the fooked one is worn inside, it will result in failure at some point, he said its for his nipper, who probably values his plums, even if no one else does.
Offline bobbbbsy
« Reply #7 on: December 30, 2012, 05:50 PM »
broken freewheels are designed to be chucked n changed hence why they screw on. even if you rebuild it there no guarantee it wont still sound like poo .. crappy clicky freewheel noise is the worst !
Offline kev-s
« Reply #8 on: December 30, 2012, 07:45 PM »
true but the £7 ones tend to be the crappy dicta ones
ive rebuilt around 6 shimano mx30 freewheels over the years, 4 of them for proper riders (not just cruising around on) with no probs and it also takes away the annoying clicking sound :daumenhoch:
most of them were just stuck on a hub and i had no tool for removing them so putting the bare body into a vice was the way i got em off :LolLolLolLol:
if the freewheel is worn then of course its not worth stripping and rebuilding as it wont fix the damage but if its just noisy because its finally lost all its lube then why waste £7 on a crappy freewheel when yours can be fixed for next to nothing :daumenhoch:
Offline bobbbbsy
« Reply #9 on: December 30, 2012, 10:16 PM »
17t suntour for a tenner !
http://www.ebay.co.uk/itm/NOS-Suntour-17-Tooth-Freewheel-3-32-Old-School-Vintage-BMX-/121041724267?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item1c2ea6236b
a cheap one provided its a good example and not defective should be fine for a nipper. kids dont exert massive force on them !
i ll rebuild hubs all day but really dont have the patience for freewheels !  :daumenhoch:
« Last Edit: December 30, 2012, 10:17 PM by bobbbbsy »
Online CustardLips
« Reply #10 on: January 02, 2013, 12:36 PM »
How long do i leave it to soak ?
"WWG1WGA"
Offline Dannywhac
« Reply #11 on: January 02, 2013, 12:48 PM »
Depends how full of sh1t it is - pull it out after 24 hours and see if it's got that gritty feel to it - give it quite e few spins to see if the grit dislodges. If it doesn't, pop it back in for another 24.
« Reply #12 on: January 02, 2013, 12:58 PM »
@ Kev S, nowt wrong with Dictas, I stick on all my bikes and they get ridden with no issues whatsoever. Also, they look the part and are excellent vfm. :daumenhoch:
« Reply #13 on: January 02, 2013, 01:04 PM »
x2   :daumenhoch:
Online CustardLips
« Reply #14 on: January 02, 2013, 01:08 PM »
Thanks fella's.  :daumenhoch:
"WWG1WGA"
Offline Gnarlyscoots
  • BANNED
« Reply #15 on: January 02, 2013, 01:09 PM »
And the seller is a member on here  :daumenhoch:  I bought one of these and it's damn perfect  :coolsmiley:  Great value for money. The Dicta's are okay for minimum mileage Dan but wait til they get dusty or proper dirty from 'non road/pavement' riding. You will change your mind then  :D
BANNED
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« Reply #16 on: January 02, 2013, 01:32 PM »
Aren't you running a 1/8 chain though?  No sloppage problems with a 3/32 freewheel?
  • BANNED
« Reply #17 on: January 02, 2013, 01:33 PM »
It's the other way round bro. You cannot run a 3/32 chain on 1/8 freewheel. The link slots are too small
BANNED
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« Reply #18 on: January 02, 2013, 01:36 PM »
Oh, i see. I've avoided buying those freewheels for nothing then, anyway i'm off to paint some tyres  ;D
Offline Jon The Bassist
« Reply #19 on: January 02, 2013, 01:38 PM »
If it's a decent freewheel and just full of gunk then get it cleaned out - I won't be binning my nearly new ACS freewheels for sure. Likewise if it's worn then just get another  :daumenhoch:
If any serious riding is to be done then you need to be looking at Suntour/Shimano as a minimum.
Online CustardLips
« Reply #20 on: January 02, 2013, 01:47 PM »
Nothing serious just a 9year old tear-arsing round the streets.  :laugh:
Might get him a dicta and keep the suntour for myself.  :daumenhoch:
"WWG1WGA"
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« Reply #21 on: January 02, 2013, 01:51 PM »
I've just bought the last 3 Suntours from the bay - fookin bargain at £8.50 a pop  >:D
  • BANNED
« Reply #22 on: January 02, 2013, 02:01 PM »
BANNED
Offline rooski
  • Mons Veneris
« Reply #23 on: January 02, 2013, 06:17 PM »
Personally i like the sound of a clicking freewheel,it reassures me that its WORKING,and i kinda like that :)
« Reply #24 on: January 02, 2013, 06:23 PM »
You certainly get that with the Shimano on my Goose Andy, I thought it was fooled. :shocked:
