Removing quick release from mx1000,tips for fitting sharp bottom boot
john4130:
just leave the quick release on, put an adjuster through the hole and you can still use the quick release.
GavinDavis:
--- Quote from: john4130 on January 01, 2013, 05:25 PM ---just leave the quick release on, put an adjuster through the hole and you can still use the quick release.
--- End quote ---
How do you mean John? You got any pics as im trying to work it out in my head ???
john4130:
like this.
GavinDavis:
Aha!!! Good stuff John :daumenhoch: ....I think i was having a bit of a blonde moment at the time ;D
SteveG:
It was a long time ago that I did mine but I carefully filed the top of the rivit down until it came off.
I re-fitted the micro adjust where the quick release was and fitted a standard cable clamp to the top.
That was back in the 80's and MX 1000'S didn't cost as much as they do now. If you can make it work OK leave the quick relaese on.
Navigation
[0] Message Index
[*] Previous page
Go to full version
