post help please
<< < (2/2)
scott250:
Cheers all, was trying to avoid the heat method as its a nice candy apple red frame.  Citric acid might be a tryer  :D
oldschoolace:
--- Quote from: scott250 on January 04, 2013, 10:09 PM ---Cheers all, was trying to avoid the heat method as its a nice candy apple red frame.  Citric acid might be a tryer  :D
--- End quote ---
 :daumenhoch: I have used it on a few rusty frames and its amazing how it shifts rust. If you have access to a vice it shouldnt be a problem at all if it doesnt just fall out  ;)
scott250:
--- Quote from: gavindavis on January 04, 2013, 10:05 PM ---Take an old stem that doesnt really mean much to you, clamp it as tight as you can around the seatpost and then put a bar/tube over the quill end to give you some leverage.  That little sucka should shift in no time....
Or failing that, use the proven blowtorch technique that our good man adenough sported recently  :LolLolLolLol:
--- End quote ---
In this case its not a goer as the post is far too low to get a stem on, cheers anyways
scott250:
--- Quote from: oldschoolace on January 04, 2013, 10:12 PM ---
--- End quote ---
--- End quote ---
Well, I'm going to give this a go, cheers  :daumenhoch:
GavinDavis:
Yep....definitely sounds like the heat method will be your preferred tactic if its too low down to grab
Navigation
[0] Message Index
[*] Previous page
Go to full version
