976242 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 07, 2026, 02:13 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  post help please
Author Topic: post help please  (Read 1967 times)
scott250
post help please
« on: January 04, 2013, 09:57 PM »
Any tips on removing a rusty seatpost from a frame please. I've tried to twist it in a vice, hammer it :idiot2: sprayed wd40 at it, no luck so far - anything else I can try? thanks
Re: post help please
« Reply #1 on: January 04, 2013, 09:59 PM »
Take a leaf out of Snapper's book and kill it with fire  :daumenhoch: smick!  :LolLolLolLol:
Offline adenough
  • Buzz Killington...
« Reply #2 on: January 04, 2013, 10:00 PM »
try a blow torch which should expand the surrounding tubing :daumenhoch:
« Reply #3 on: January 04, 2013, 10:02 PM »
Or my prefered way is to bung up any week hole to the bb and fill the seat tube to the stop with a strong solution of citric acid.
One or two of the little 50mg tubs used for home brews should do the trick. Give it 24 hours  :daumenhoch:
http://www.wilkinsonplus.com/home-brewing/wilko-citric-acid-50g/invt/0022652/
« Last Edit: January 04, 2013, 10:06 PM by oldschoolace »
Offline GavinDavis
« Reply #4 on: January 04, 2013, 10:05 PM »
Take an old stem that doesnt really mean much to you, clamp it as tight as you can around the seatpost and then put a bar/tube over the quill end to give you some leverage.  That little sucka should shift in no time....
Or failing that, use the proven blowtorch technique that our good man adenough sported recently  :LolLolLolLol:
scott250
« Reply #5 on: January 04, 2013, 10:09 PM »
Cheers all, was trying to avoid the heat method as its a nice candy apple red frame.  Citric acid might be a tryer  :D
« Reply #6 on: January 04, 2013, 10:12 PM »
 :daumenhoch: I have used it on a few rusty frames and its amazing how it shifts rust. If you have access to a vice it shouldnt be a problem at all if it doesnt just fall out  ;)
scott250
« Reply #7 on: January 04, 2013, 10:18 PM »
In this case its not a goer as the post is far too low to get a stem on, cheers anyways
scott250
« Reply #8 on: January 04, 2013, 10:21 PM »
Well, I'm going to give this a go, cheers  :daumenhoch:
Offline GavinDavis
« Reply #9 on: January 05, 2013, 09:18 AM »
Yep....definitely sounds like the heat method will be your preferred tactic if its too low down to grab
