976242 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 07, 2026, 01:23 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Heeeeeelp!!
Author Topic: Heeeeeelp!!  (Read 2171 times)
Mdbh
Heeeeeelp!!
« on: January 06, 2013, 10:02 AM »
How the hell am I going to get this out? The hex bit where the Allen key go's in has snapped!:( I've tried the screw drive/hammer route but it won't budge as ithink it's under load! This is a top cap thing that's on odyssey race forks? Anybody had this problem before?
Offline Discostu
  • Two's Company
Re: Heeeeeelp!!
« Reply #1 on: January 06, 2013, 10:12 AM »
I would try a little heat on it first to break the join. Then carry on tapping it around. Use a centre punch to tap it.  :daumenhoch:
Mdbh
Re: Heeeeeelp!!
« Reply #2 on: January 06, 2013, 10:18 AM »
I was gone but a new headset as I've had this 1 for a while and is tatty but bollox to it, I've done it all bk up now lol it can stay like that for a bit longer :LolLolLolLol:
Offline Peter J
  • I have issues
Re: Heeeeeelp!!
« Reply #3 on: January 06, 2013, 10:20 AM »
Get the biggest flat blade screwdriver you have and a normal sized hammer and keep tapping at a 45 Degree angle where the arrow is
Just done the same to one last night
Oh before you do it loosen the two bolts and brace the front wheel between your legs
Also give it a good squirt of WD-40
Offline Dannywhac
  • return of the whac
Re: Heeeeeelp!!
« Reply #4 on: January 06, 2013, 11:12 AM »
X2  :daumenhoch:
They're a sh1t design - 'kin hate 'em. Rather than use heat on it you can also sometimes get em going after loosening the bolts, front wheel in legs and give the bars a good prod anti-clockwise. That'll get it going n'all.
Offline Munnyella
Re: Heeeeeelp!!
« Reply #5 on: January 06, 2013, 12:43 PM »
wide chisel in the hole at its widest point, adjustable spanner on the chisel, undo.
MM
Offline adenough
  • Buzz Killington...
Re: Heeeeeelp!!
« Reply #6 on: January 06, 2013, 12:49 PM »
id take a hacksaw blade and (if its ally) saw straight down towards the gap, wont take long  :daumenhoch: :daumenhoch:
Re: Heeeeeelp!!
« Reply #7 on: January 06, 2013, 01:05 PM »
are the 2 bolts out of the side ?  you should just be able to hold the front wheel/fork and turn the bars ,it will undo the top nut.
Offline GavinDavis
Re: Heeeeeelp!!
« Reply #8 on: January 06, 2013, 01:09 PM »
Ahh I was expecting at least the blowtorch method  ;D
Offline adenough
Re: Heeeeeelp!!
« Reply #9 on: January 06, 2013, 01:42 PM »
mmm (rubs chin)  :LolLolLolLol:
Re: Heeeeeelp!!
« Reply #10 on: January 06, 2013, 02:49 PM »
Offline adenough
Re: Heeeeeelp!!
« Reply #11 on: January 06, 2013, 02:59 PM »
