976242 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 07, 2026, 12:32 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  what container do you use when doing a OA bath
Author Topic: what container do you use when doing a OA bath  (Read 11879 times)
Offline kalex
« on: January 09, 2013, 06:07 PM »
i can't find a large plastic storage tub long enough to put my frame in so i can give it a OA bath
the inner measurements need to be L=95cm x W 35cm x D 25cm
BENDYCAT ELEVENTEEN has already said a kids sand pit thingy, but the one my kids have got is half the size ( thought it would have done until i fished it out)
so any suggestions of what i could use or where to get a larger storage box
i'm sure i've seen pics of frames in these under bed tubs
bmx xxx
Re: what container do you use when doing a OA bath
« Reply #1 on: January 09, 2013, 06:08 PM »
i use a plasters bath,
works a treat,
im in se23 if your close you can nick it for a few weeks.
gary
Offline kalex
« Reply #2 on: January 09, 2013, 06:12 PM »
works a treat,
gary
thanks mate but just googled se23 and i'm miles away
Offline Dannywhac
  • return of the whac
« Reply #3 on: January 09, 2013, 06:13 PM »
The bath (the missus will forgive you if you tell her it cleans the bath  :D ):
bmx xxx
« Reply #4 on: January 09, 2013, 06:16 PM »
fooking hell how do you get away with that.
Offline kalex
« Reply #5 on: January 09, 2013, 06:18 PM »
that has crossed my mind, but it took my over three years to gut our old bathroom and re-fit a new one. but i did do all the tiling,plumbing etc myself
so my wife would kill me if i even asked
Offline Dannywhac
« Reply #6 on: January 09, 2013, 06:20 PM »
A lot of persuasion, and the fact we need a new bathroom (which I also will be fitting/plumbing). That and waiting for her to go out  ;D
« Reply #7 on: January 09, 2013, 06:22 PM »
Borrow one of my mums Wheelie Bins when she not looking  :LolLolLolLol:
Offline stevesredvxr
« Reply #8 on: January 09, 2013, 07:06 PM »
This what I use.....bought it off the bay 2nd hand, but not used, for a tenner!!!
It's a large plastic dog bath. Perfect.  :daumenhoch:
« Last Edit: January 09, 2013, 07:13 PM by stevesredvxr »
Offline kalex
« Reply #9 on: January 09, 2013, 07:15 PM »
Bmx xxx put me on to plasters baths and when i looked on ebay dog baths also came up
But all around £25 +
« Reply #10 on: January 09, 2013, 08:09 PM »
where are you ?
Offline GavinDavis
« Reply #11 on: January 09, 2013, 08:12 PM »
I use the large plastic section that comes of the bottom of what i can only presume is a rabbit cage thing??
We found it in the shed when we moved in  ;D
Offline rooski
  • Mons Veneris
« Reply #12 on: January 09, 2013, 08:15 PM »
Get an old plastic bath out of a skip,do the bike,replace bath in skip.
« Reply #13 on: January 09, 2013, 08:26 PM »
the thing is with needing a AO bath is the volume used and amount of water to solution
you need it to be shallow and big width way
a big tub will need filling up to cover the item - more water and more OA = more ££ spent
so some thing that doesn't need bottles of water to make up the volume will be best
any thing near you on gumtree ?
Offline kalex
« Reply #14 on: January 09, 2013, 08:51 PM »
i'm going to my local builders merchants tomorrrow or friday to see if they sell plasterers baths.
failing that, from doing my bathroom i got to know the chaps in our local trade plumbing supplies ( and i don't mean homebase ). i'll pop in there and ask if they've got any damaged plastic baths (damage around the top of the bath and not big holes in the bottom) that they are going to bin.
« Reply #15 on: January 09, 2013, 09:00 PM »
This is my usual rig for citric acid. Pound shop specials  :daumenhoch:
Offline kalex
« Reply #16 on: January 09, 2013, 09:03 PM »
does citric acid work the same as oxalic acid
where can you get it from and in what form does it come in
« Reply #17 on: January 09, 2013, 09:10 PM »
As far as i know they work exactly the same. Citric acid comes in granules like sugar and you can get it from any home brew supply shop or cheaper on the bay. Totally safe too as most drinks and tons of food contain it.
the residue you see in the pic is what came of this frame  :daumenhoch:
Before
After
Offline kalex
« Reply #18 on: January 09, 2013, 09:14 PM »
very good results you've got there  :daumenhoch:
i chucked the kids little blow up pool out last year
what type of ratio did you use and time scale
Offline Dannywhac
« Reply #19 on: January 09, 2013, 09:18 PM »
I use Citric as every now and again you get a frame with sh1t chrome, and OA can leave 'bruise' stains (which sometimes can be polished out) whereas CA doesn't. Plus like OSA says, CA's a bit easier going than OA.
Homebrew supplies will do 500g of CA for around the £4.50 mark, or get it on eBay cheaper:
http://www.ebay.co.uk/itm/500g-CITRIC-ACID-FOOD-GRADE-HOME-BREW-WINE-MAKING-/150718206562?pt=UK_HomeGarden_CLV_Cleaning_CA&hash=item2317815262
http://www.ebay.co.uk/itm/1000g-1kg-Citric-Acid-food-grade-Long-shelf-life-for-brewing-bath-bombs-descaler-/270958120373?pt=UK_Home_Garden_Food_SM&hash=item3f165ccdb5
Ratio - depends on how long you can leave it in the container - slower = better results with a slightly weaker solution. 20:1 (as in gallons to kg), or a half full bath with around 400/500g in it will do it's work over 24-48 hours depending on the rust. You should keep an eye on the frames etc, and every now and again give the stubborn bits a going over with a toothbrush or washing-up scourer (gently).
Should be said - if the item you're cleaning isn't chrome (ie rusty bare metal) both CA and OA will shift the rust, but make the metal have a 'dusty' dark oxide on it's surface.
Always thoroughly rinse (including inside tubes) with clean water after you've dipped them, dry them off on a radiator or somewhere warm, and give tube insides a few squirts of WD or similar to make sure there's no acid still working away inside.
« Last Edit: January 09, 2013, 09:22 PM by dannywhac »
« Reply #20 on: January 09, 2013, 09:23 PM »
Ratios vary the timescale but i generally use anywhere between 250/400g of the powder per paddling pool bath depending on what i can get my hands on. 24 hours is usually enough, rubbing stubborn bits with a toothbrush a few times.
Top tips are to fill pop bottles with plain water and put in and around the frame taking up volume and saving citric acid needed. If you are really tight or are doing smaller things in little tubs you can keep it and use it again a few times.
The pool i used was only a 1 metre one that i distort to suit the frame shape and save more volume  :daumenhoch:
Offline kalex
« Reply #21 on: January 09, 2013, 09:31 PM »
thanks for your replies for the citric acid
i've already got the oa from other little jobs, but if i can't get a plastic tub local.
i will try the citric in a blow up pool.
i would have thought the oxalic acid would be fine in the pool as it doesn't eat through decals, but after already having my garage floor cleaned to day from a failed attempt i'm going to play it save
Offline skki3330
  • Love Riding Old Bikes
« Reply #22 on: January 09, 2013, 09:42 PM »
Yep im to currently searchin for a tub to use.
WANTED
SE Powerwings
Holeshot RF-1
Offline kalex
« Reply #23 on: January 09, 2013, 09:55 PM »
i may just take the plunge on a cheapo kids blow up pool
for either citric or oxalic acid, how i see it people leave the decals in place and they come out ok. so it should be fine in the pool
Offline skki3330
« Reply #24 on: January 09, 2013, 10:56 PM »
Bud let me know if you find one a good size, ive got 2 frames that need dipping
WANTED
SE Powerwings
Holeshot RF-1
