976241 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 07, 2026, 08:48 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Oxalic
Author Topic: Oxalic  (Read 1789 times)
leehunt1
Oxalic
« on: January 20, 2013, 06:33 PM »
Offline Dannywhac
  • return of the whac
leehunt1
Re: Oxalic
« Reply #2 on: January 20, 2013, 06:41 PM »
Cool.. :daumenhoch:
Do you know the mix quantities ?
Im doing some forks with only a small amount of rust
Offline midschooljon
    • Make Your Bones
Re: Oxalic
« Reply #3 on: January 20, 2013, 07:22 PM »
The more you use the faster it works, but you dont need much. If all you are doing is a set of forks, and the container isnt massive, you will easily clean them up with 3-4 table spoons of the crystals. if the container is big with lots of water you will need to increase the quantity.
***Wanted - Cash waiting***
RAMP ROOM HOFFMAN FLASH
ELF Double Cross XL.
UGP plates and pad sets
Mid School Race Kit
leehunt1
Re: Oxalic
« Reply #4 on: January 20, 2013, 07:28 PM »
Offline Dannywhac
Re: Oxalic
« Reply #5 on: January 20, 2013, 07:36 PM »
Slower is better - don't go sticking fook loads in from the get go, remember you can always add more - I use 500g for a half full bath, with a bit of light scrubbing with an old toothbrush on stubborn bits. Leave em in there for around 24 hours, but check back on them after 6 to see if they're done.
Re: Oxalic
« Reply #6 on: January 20, 2013, 07:43 PM »
I accidently put 750gms into a tub that just held a frame ... left for 24 hours ... pffftt it was fine  :angel:
...but Dan is right ... less for longer is safer  :daumenhoch: nice hot water helps as well.
Pour it on green alge covered garden chairs after  :angel: works a treat.
« Last Edit: January 21, 2013, 07:59 AM by ED209 »
Re: Oxalic
« Reply #7 on: January 20, 2013, 10:59 PM »
don't forget to put pop bottles/bricks/whatever in the gaps between the frame & tub
fills it up so you don't need so much water in there  :daumenhoch:
leehunt1
Re: Oxalic
« Reply #8 on: January 21, 2013, 07:41 AM »
Wow thanks griff  :daumenhoch:
Great idea x
