Odyssey Forks
<< < (2/2)
Dannywhac:
I've got a pair of Redline 1 1/8" with AD lugs 14mm forks you can have fella from 2002 that'd fit your standard headset dealio. Don't want owt for em, and I'm conveniently located in Bury ;)
Radical Mick:
--- Quote from: dannywhac on January 30, 2013, 06:13 PM ---I've got a pair of Redline 1 1/8" with AD lugs 14mm forks you can have fella from 2002 that'd fit your standard headset dealio. Don't want owt for em, and I'm conveniently located in Bury ;)
--- End quote ---
Thanks! :daumenhoch:
Was going to try and get a pair without AD lugs but I'm not going to turn down a free pair of forks, and the AD lugs are probably more
in line with most bikes of that age. The front wheel I have got has 10mm axles is this a problem with 14mm forks. I have read about
adaptors.
Going to send the frame and fork to SuperbikeDan for powder coating.
Will PM you with my contact details.
CD17:
--- Quote from: VOIVOD on January 30, 2013, 03:56 PM --- :) Does your T1 have regular headset cups? Odyssey forks have a built-in crown race that is designed to fit with headsets with a 45 degree lower bearing....
--- End quote ---
I think the early ones don't have the built in crown race, but will be quite hard to find, I know Steve Wilson had a pair  ???
Spen69:
--- Quote from: Radical Mick on January 30, 2013, 09:10 PM ---Was going to try and get a pair without AD lugs but I'm not going to turn down a free pair of forks....
--- End quote ---
If you're going to powder them then why not cut the lugs off amd grind them flush before Dan works his magic ???
Radical Mick:
--- Quote from: Spen69 on January 30, 2013, 10:30 PM ---
--- End quote ---
--- End quote ---
Good idea, hadn't thought of that. Thanks :daumenhoch:
Navigation
[0] Message Index
[*] Previous page
Go to full version
