976241 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 07, 2026, 04:06 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Odyssey Forks
Author Topic: Odyssey Forks  (Read 2227 times)
Radical Mick
Odyssey Forks
« on: January 30, 2013, 01:44 PM »
I'm looking to get a pair of Odyssey forks to go with my 2001/2 T1 Barcode frame.
Looking at the ones for sale on e-bay I have noticed that the hole in the top cap seems off centre,  :wtf:
Is this something special to Odyssey forks only?
I have brought an FSA pig headset, is it compatible with Odyssey forks or must I use the Odyssey top-cap system?
Any help/suggestions appreciated :)
Re: Odyssey Forks
« Reply #1 on: January 30, 2013, 01:58 PM »
If they use the same topcap as my Director forks they are internally threaded rather than using a star washer thingy. The offset hole you mention is actually where you tighten the cap up with an 8mm Allen key :daumenhoch:
Radical Mick
Re: Odyssey Forks
« Reply #2 on: January 30, 2013, 02:05 PM »
That makes sense, thanks for that.  :daumenhoch:
Think I should probably be able to use the Headset I have and leave the star washer and top cap from the FSA headset out.
HEYWOOD BMX
Re: Odyssey Forks
« Reply #3 on: January 30, 2013, 03:56 PM »
 :) Does your T1 have regular headset cups? Odyssey forks have a built-in crown race that is designed to fit with headsets with a 45 degree lower bearing....
Re: Odyssey Forks
« Reply #4 on: January 30, 2013, 06:10 PM »
The offset hole also allows for routing a cable through for a front brake but still be able to tighten it up  :daumenhoch:
Offline Dannywhac
  • return of the whac
Re: Odyssey Forks
« Reply #5 on: January 30, 2013, 06:13 PM »
I've got a pair of Redline 1 1/8" with AD lugs 14mm forks you can have fella from 2002 that'd fit your standard headset dealio. Don't want owt for em, and I'm conveniently located in Bury ;)
Radical Mick
Re: Odyssey Forks
« Reply #6 on: January 30, 2013, 09:10 PM »
Thanks! :daumenhoch:
Was going to try and get a pair without AD lugs but I'm not going to turn down a free pair of forks, and the AD lugs are probably more
in line with most bikes of that age. The front wheel I have got has 10mm axles is this a problem with 14mm forks. I have read about
adaptors.
Going to send the frame and fork to SuperbikeDan for powder coating.
Will PM you with my contact details.
Re: Odyssey Forks
« Reply #7 on: January 30, 2013, 09:47 PM »
I think the early ones don't have the built in crown race, but will be quite hard to find, I know Steve Wilson had a pair  ???
Re: Odyssey Forks
« Reply #8 on: January 30, 2013, 10:30 PM »
Was going to try and get a pair without AD lugs but I'm not going to turn down a free pair of forks....
If you're going to powder them then why not cut the lugs off amd grind them flush before Dan works his magic ???
Radical Mick
Re: Odyssey Forks
« Reply #9 on: January 31, 2013, 04:41 PM »
Good idea, hadn't thought of that. Thanks :daumenhoch:
