976334 Posts in 138997 Topics by 6434 Members - Latest Member: Darbs August 07, 2026, 09:32 PM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  Old school chain, how many links?
Author Topic: Old school chain, how many links?  (Read 3007 times)
paulb113
« on: January 31, 2013, 05:53 PM »
I am getting a 1986 Haro Fst built at the moment and looking to buy a chain for it. the rear freewheel has 18 teeth and I think the chain wheel is 39 teeth.  How many links does it need? Some say 110link others 90link.
Offline That Swan Guy
Re: Old school chain, how many links?
« Reply #1 on: January 31, 2013, 05:58 PM »
depends how far back you put the rear wheel. 110 will do you fine, you can always take the spare ones off. Nothing worse than being one link short. 90? sure it doesn't say 96. That's the normal amount. 96 or 110.
paulb113
« Reply #2 on: January 31, 2013, 06:09 PM »
Thanks. Seen a KMC one in silver for a tenner plus postage,or is it worth spending a bit more on an Izumi one?
« Reply #3 on: January 31, 2013, 06:10 PM »
If you're going to ride it, probably not.
Offline Betty
« Reply #4 on: January 31, 2013, 06:12 PM »
39/18 will be a bit slack  :shocked:
2 minutes turkish...
« Reply #5 on: January 31, 2013, 06:23 PM »
Paul what I tend to do is true the rim up to my brake blocks, then push the wheel forward half an inch, them I remove enough links to leave a fairly slack chain. Once linked together and fitted, pull the wheel back to its original position in the dropouts, remembering to centre the wheel whilst doing this.
Your chain should be tight but with a small amount of bounce. Making your chain as tight as possible will destroy your freewheel. :daumenhoch:
paulb113
« Reply #6 on: January 31, 2013, 09:02 PM »
Joff (NORTY40) and Darren (BADDH) are helping me with the build so they know how to shorten the chain etc, it's been a long time since I had put a bmx together!! :LolLolLolLol:
« Reply #7 on: January 31, 2013, 09:08 PM »
Paul them to clowns could'nt sort a jump in a brothel  :LolLolLolLol:  ....  they,ll just sit around eating pies all day  :2funny:
« Reply #8 on: January 31, 2013, 09:17 PM »
If you do it while Joffs there, you will get injured.....FACT!! ;)
« Reply #9 on: February 02, 2013, 03:40 AM »
The Dazzler & Joff show's in town eh Paul? I'd have a word about that gearing as it sounds to me like they're building you one of Kappy's clown bikes fella...... You'll be pedalling like a lunatic!
39 on the front = 14 on the back mate...... Not 18 ::)
Or 18 on the back = a coping-crunching 49/50 on the front....
Give the pair of simpletons a hug from me will ya ???
Spen
« Last Edit: February 02, 2013, 04:07 AM by Spen69 »
Offline BADDH
  • BMX
« Reply #10 on: February 02, 2013, 07:17 AM »
Paul was never built for speed  :LolLolLolLol:
Bad Baldie I am on't third Meyt N Pratur pie at moment ..... How's that sliding down thill on planks going lad   :LolLolLolLol:
Jaypeg
« Reply #11 on: February 02, 2013, 07:49 AM »
I divide the number of teeth on my chainring by 2.75 to get the right size freewheel or just go with what spen said as he is correct ... :daumenhoch:
« Last Edit: February 02, 2013, 06:49 PM by Jaypeg »
paulb113
« Reply #12 on: February 03, 2013, 10:56 AM »
Darren is the front 39? I don't want to have to pedal like mad :LolLolLolLol:
Where is the best place to get a 14t rear one from?
I don't remember it being so complicated BITD  :D
Yes ,I was not built for speed even less now as I only have one good leg after a roller skating accident  :LolLolLolLol:
« Reply #13 on: February 03, 2013, 11:14 AM »
Good for going up Bright street on  :daumenhoch:
HEYWOOD BMX
« Reply #14 on: February 03, 2013, 11:19 AM »
 You`ll need a cassette or flipflop hub to run a 14t rear cog. :daumenhoch:
I have an unused 1/8 14T freewheel you can have for cost of post if you want it....
« Last Edit: February 03, 2013, 11:26 AM by VOIVOD »
paulb113
« Reply #15 on: February 03, 2013, 02:25 PM »
This is the wheel and freewheel
