976334 Posts in 138997 Topics by 6434 Members - Latest Member: Darbs August 07, 2026, 08:40 PM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  Will it work ?
Author Topic: Will it work ?  (Read 1798 times)
Offline Peter J
  • I have issues
Will it work ?
« on: February 02, 2013, 04:20 PM »
I would have thought you'd need a V pulley  ???
Re: Will it work ?
« Reply #1 on: February 02, 2013, 08:57 PM »
Interesting! Be good to see the full set up!
Offline GavinDavis
Re: Will it work ?
« Reply #2 on: February 02, 2013, 09:15 PM »
I would have thought that would need some serious tension so it didnt slip.  Would certainly save a bit of weight though for the lightweight junkies out there! :)
chubby
Re: Will it work ?
« Reply #3 on: February 02, 2013, 09:47 PM »
if it's anything like the timing belts I've done lately it'll be fine fella  :LolLolLolLol: good for at least 60k
Re: Will it work ?
« Reply #4 on: February 02, 2013, 10:10 PM »
slip off - to A&E  :buck2:
Offline Munnyella
Re: Will it work ?
« Reply #5 on: February 02, 2013, 10:26 PM »
Will it squeal like my Scirocco in the wet??
if it was gonna work, we'd have been using this system for years, same with shaft drive.
It ain't broke, don't fix it.
MM
Re: Will it work ?
« Reply #6 on: February 02, 2013, 11:02 PM »
How would you get it to fit?
A chain has to be split before it can be fitted and it's adjustable for length. Some sort of spring loaded tensioner would take care of any length issues but how would you get it on the frame in the first place?
bof
Re: Will it work ?
« Reply #7 on: February 02, 2013, 11:08 PM »
The frame has to pull apart somewhere to allow the belt to be installed, but Pete's right I would prefer v pulleys to stop the belt slipping sideways
