976241 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 06, 2026, 10:18 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Help needed on how to remove.....
Author Topic: Help needed on how to remove.....  (Read 1670 times)
Offline adenough
  • Buzz Killington...
« on: February 24, 2013, 04:19 PM »
the spindles from these hubs, probably a thick question but ive never done this before, spent the last few hours stripping the shot chrome from these.........thanks :daumenhoch:
Offline bobbbbsy
Re: Help needed on how to remove.....
« Reply #1 on: February 24, 2013, 04:25 PM »
laying off the funny fags might be a start rog  :buck2: :daumenhoch:
Offline adenough
« Reply #2 on: February 24, 2013, 04:30 PM »
:angel:
Offline Discostu
  • Two's Company
« Reply #3 on: February 24, 2013, 04:33 PM »
I would say you need to Undo the clamp on retaining cones. Then unwind them off the axle.
Then put a nut on the end of the axle to protect the threaded end. Then gently tap the axle out. This will push the bearing out with the axle as the axle should have 2 shoulders which sit against the inner bearing races. (I'm assuming this are sealed hubs with cartridge bearings)
You then remove the bearing from the axle. This should just tap off without much fuss. Then put the axle back into the hub and tap the other bearing out the same as the first one.  :daumenhoch:
Offline adenough
« Reply #4 on: February 24, 2013, 04:36 PM »
Now that sounds like a plan, thanks  :daumenhoch:
Offline Discostu
  • Two's Company
« Reply #5 on: February 24, 2013, 04:39 PM »
You can use an adjustable on the flats of the axle plus leave the alan key in the cone bolt hole to help unwind the cones.  :daumenhoch:
Offline adenough
« Reply #6 on: February 24, 2013, 04:40 PM »
 :daumenhoch: :daumenhoch:
