976241 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 06, 2026, 08:39 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  skyway axles, how tight?
Author Topic: skyway axles, how tight?  (Read 2155 times)
Offline stevepeanut
« on: February 27, 2013, 03:46 PM »
I am just putting my axles back into my skyways, I have never done this before. I have put the bearings in each side, put the metal cups on, how tight to I screw on the first nut*?
*not a nut but the circular bit of metal with the flats on the side
Sid1972
Re: skyway axles, how tight?
« Reply #1 on: February 27, 2013, 04:22 PM »
its a fine line - the wheel should spin free but have no sideways movement. Just keep adjusting it and then spin the wheel, you will get it right it may just take a couple of goes.  ;)
Offline stevepeanut
« Reply #2 on: February 27, 2013, 06:13 PM »
cheers Sid,
Sorted now but had a struggle, managed to play around and too slack I could feel movement, too right and the wheel was not spinning freely. As soon as I started tighetening the outer nuts on the forks, it was turning the inside axle nuts and putting pressure on the bearings and making the wheel tight. I got an angle grinder on an old spanner and halved the thickness of the spanner head making a thin spanner so I could stop the inner nuts moving, while tightening the outer ones. Sorted  :)
Offline not johndub71
« Reply #3 on: February 27, 2013, 08:20 PM »
Circle bit with flats = cones.
Facebook/Fr35Hair
Offline stevepeanut
« Reply #4 on: February 27, 2013, 08:27 PM »
cheers, now I remember I have heard the term cone spanner
must be the same as what I made
« Reply #5 on: February 27, 2013, 08:55 PM »
Cones should really just be finger tight and the bearings should run smoothly, then the hex locking nut gets tightened up against the cone nut  :daumenhoch:
Offline stevepeanut
« Reply #6 on: February 27, 2013, 09:18 PM »
Thats pretty much how I did it through trial and error
« Reply #7 on: February 28, 2013, 10:37 AM »
Yup, cone spanners are thin steel spanners. Best ones are the really old bike spanner combos you could get on 70s/80s bikes. I used to feck no end up when I worked at Raynes. Another skiving method is lock one side up, fit wheel in frame or forks, tighten that side up on the frame and adjust. Sometimes a slight bit of play can't be picked up by spinning by hand.
Facebook/Fr35Hair
