976241 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 06, 2026, 08:43 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Removing grips without damaging them or the bars ???
Author Topic: Removing grips without damaging them or the bars ???  (Read 5305 times)
Offline Funkyworm
« on: March 02, 2013, 11:49 AM »
Ok , bit of a novice thing to be asking but i wondered if anyone had a reasonable way to do this?
Back in the day we used some WD & slid a kitchen Knife down the grip to enable the oil to loosen the grip from the bars with varying degrees of success injuries & damage caused to the both grips bars ourselves & any unfortunate passers by...... :-X
I need to remove some grips from my bars as I think I'm adding some tech 6 levers which need to slide on so any advice would be greatly appreciated.
Cheers ! :daumenhoch:
« Last Edit: March 02, 2013, 11:52 AM by Funkyworm »
deeman
Re: Removing grips without damaging them or the bars ???
« Reply #1 on: March 02, 2013, 11:52 AM »
Take bars off.dip the grips in hot water one at a time and with your fingers stretch the hole so as much water gets down as poss.Take out of water and wrestle off with tea towel.It works,done it a few times :daumenhoch:
« Last Edit: March 02, 2013, 12:01 PM by deeman »
« Reply #2 on: March 02, 2013, 11:54 AM »
Hairspray  ;) Spray it in and work it down and they will slide off  :daumenhoch: Use it 2 fit aswell cos it evaporates and lightly sticks the the grips 2 bars  8) U should have seen my misses face when I bought a can  :LolLolLolLol: being folically challenged she said " what the fook do u want that 4" and pissed herself laughing  :2funny:
Rodgy1970
« Reply #3 on: March 02, 2013, 11:55 AM »
Feed WD40 or straw down between bar and grip.
Squirt, feed and twist the grip should come off no problem.
Offline sawzall
« Reply #4 on: March 02, 2013, 11:56 AM »
i use a lolly stick,work it down the grip with washing up liquid,then move your way around grip
repeating the process and it should slide off :daumenhoch:
Offline Funkyworm
« Reply #5 on: March 02, 2013, 11:58 AM »
Cheers guys,
Some good suggestions !
The hairspray one sounds bizarre  :daumenhoch:
« Reply #6 on: March 02, 2013, 12:10 PM »
Cheers guys,
thats me  :2funny:
Offline sawzall
« Reply #7 on: March 02, 2013, 12:18 PM »
im with you on that steve,i always have a can in my workshop,the best way to put grips on :daumenhoch:
« Reply #8 on: March 02, 2013, 12:23 PM »
I go the kettle of hot water in a jug and marrigolds route.
Offline Devilock
« Reply #9 on: March 02, 2013, 12:23 PM »
I think them off...
Offline Julian347
« Reply #10 on: March 02, 2013, 12:27 PM »
WD40 to remove, hairspray to put back on.  :daumenhoch:
Rodgy1970
« Reply #11 on: March 02, 2013, 12:34 PM »
I stopped using the hairspray on anything I'm going to ride after grips worked loose on a wet day on MTB.
deeman
« Reply #12 on: March 02, 2013, 12:47 PM »
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« Reply #13 on: March 02, 2013, 01:31 PM »
Very thin flat head screwdriver, I wrap it in masking tape to avoid scratching. Push it all the way down, slide the WD40 straw next to it and spray, the WD makes its way around in seconds and the grip slides off - viola!
ozone
« Reply #14 on: March 02, 2013, 04:16 PM »
A chopstick and squeezy for me.   :daumenhoch:
Offline Wez
  • What's Happenin' Derek ???
« Reply #15 on: March 02, 2013, 04:21 PM »
Deoderant, every time, on & off ;)
the misses usually ..
Offline bobbbbsy
« Reply #16 on: March 02, 2013, 04:24 PM »
i remember once stripping an old bike in the garage with a cuppa on the go , got to this stage , took a sip , pulled the flange so the grip came off the bar a little and spat my sip of tea down the gap and worked one off . repeated for other side  :daumenhoch:
tea does not degrade your rubbers like all the nasty chemicals these other folk use  :'(
« Last Edit: March 02, 2013, 04:36 PM by bobbbbsy »
nosepickben
« Reply #17 on: March 02, 2013, 05:11 PM »
The only way to get them off in a way which causes no problems with re installation is to man up and wrestle them off. The bars need to be on the bike still for maximum leverage. You may need to grimace and shout during removal, most importantly, you need to be a man and not a girl. If you introduce any fluids, they might come off easier, but they never stay put when replaced.
Offline bobbbbsy
« Reply #18 on: March 02, 2013, 05:46 PM »
um. you let them dry then re fit with some spit which drys after a few days !  :daumenhoch:
Offline not johndub71
« Reply #19 on: March 02, 2013, 07:58 PM »
Knife em...
Facebook/Fr35Hair
Offline SteveG
« Reply #20 on: March 02, 2013, 08:47 PM »
I have used a quick squirt of brake cleaner to fit grips recently. It evaporates and doesn't leave anything nasty behind.
This might not be a good idea on painted bars and there is the chance it could make the grip go a bit funny depending on what they are made of. It was fine on chrome bars and rubber grips I put on my daughters MTB.
cdt808
« Reply #21 on: March 02, 2013, 08:57 PM »
defo agree with the posts above about hot water. dip the bar end into a vase of the hot stuff and it will soften the grips up and make them far easier to remove. Once cold and dry they are as good as new....
deeman
« Reply #22 on: March 02, 2013, 09:17 PM »
Brake cleaner is basically thinners dude!I wouldn't use that! :daumenhoch:
Offline senzo milano
« Reply #23 on: March 05, 2013, 08:42 PM »
Why using hairspray to put them back on ?
Big bobbles ,no troubles
Offline stevepeanut
« Reply #24 on: March 05, 2013, 09:36 PM »
The spray is nice and wet so the grip slides on easy, then the spray sets and turns sticky, so the grips are stuck to the bars and don't move.
