976239 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 06, 2026, 06:46 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Removing grips without damaging them or the bars ???
Author Topic: Removing grips without damaging them or the bars ???  (Read 5296 times)
Offline senzo milano
Re: Removing grips without damaging them or the bars ???
« Reply #25 on: March 05, 2013, 09:46 PM »
Why using hairspray to put them back on ?
The spray is nice and wet so the grip slides on easy, then the spray sets and turns sticky, so the grips are stuck to the bars and don't move.
and how to remove the grips later?  ;D
Big bobbles ,no troubles
Offline Wez
  • What's Happenin' Derek ???
« Reply #26 on: March 05, 2013, 09:49 PM »
hair gel ;)
« Reply #27 on: March 05, 2013, 09:57 PM »
hair gel ;)
Ohh watch the "Grease lightning"  :D
Offline stevepeanut
« Reply #28 on: March 05, 2013, 10:03 PM »
hair spray sets and makes the grips stick good, but its also fine when you want to remove them, washing up liquid or wd40 and they come off again ok
Offline bobbbbsy
« Reply #29 on: March 05, 2013, 10:05 PM »
I have used a quick squirt of brake cleaner to fit grips recently. It evaporates and doesn't leave anything nasty behind.
This might not be a good idea on painted bars and there is the chance it could make the grip go a bit funny depending on what they are made of. It was fine on chrome bars and rubber grips I put on my daughters MTB.
brake n carb cleaner is nasty shit
« Reply #30 on: March 05, 2013, 10:07 PM »
but you have to lift the grip , to let the WD40 flow between the grip and bars. And i think you have to use a tool for that.
So you can damage also the bars with it  :'(
Offline stevepeanut
« Reply #31 on: March 05, 2013, 10:12 PM »
a jewellers screwdriver is enough to lift it without damaging the grip or bars
« Reply #32 on: March 06, 2013, 07:35 PM »
You have the solution for every thing Steven  :daumenhoch:
cheers Patric
Offline Gary72
« Reply #33 on: March 06, 2013, 07:41 PM »
WD-40 with thin red straw to remove. Cable ties to fit grips, No waiting for things to dry, Fit and ride :daumenhoch:
Offline fugazi
« Reply #34 on: March 08, 2013, 12:45 PM »
I use those thin wooden Kebab skewers (ello matey peeps) & either wd40 type stuff or just water to get 'em off. Hairspray 'em on  :daumenhoch:
