976239 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 06, 2026, 06:46 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Potts Mod - MX1000
Author Topic: Potts Mod - MX1000  (Read 3821 times)
Offline Devilock
Potts Mod - MX1000
« on: March 09, 2013, 05:05 PM »
I want to start building my Ruffell rep but need to mod the front 1000... Ive never done it before so how do I remove the quick release?
Re: Potts Mod - MX1000
« Reply #1 on: March 09, 2013, 05:10 PM »
Use the force Rich  :)
or a drill  :daumenhoch:
Offline Devilock
« Reply #2 on: March 09, 2013, 05:12 PM »
I have to drill it...?!! Got any step by step pics?!! :-[
« Reply #3 on: March 09, 2013, 05:14 PM »
rich I managed it when I was 15 so I'm sure you can do it... just drill the fixing through the hole, or grind the end off until the quick release drops off  :D  :daumenhoch:
« Reply #4 on: March 09, 2013, 05:16 PM »
its also been done with it still on..
Offline Devilock
« Reply #5 on: March 09, 2013, 05:22 PM »
I like that idea! Looks easier!  ;D Although I need to have it exactly the same as Neil's...but not 100% which one he had...
Offline Devilock
« Reply #6 on: March 09, 2013, 05:29 PM »
Just thought, I dont have a drill!!!
« Reply #7 on: March 09, 2013, 06:09 PM »
he had it drilled off with the weimann adjuster in its place.
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« Reply #8 on: March 09, 2013, 06:17 PM »
Build a different bike
Offline Devilock
« Reply #9 on: March 09, 2013, 06:32 PM »
Thanks for confirming that Dave...& Chris Ill have you at 3.30 after school!
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« Reply #10 on: March 09, 2013, 08:22 PM »
For a blowie?  :-*
Offline sawzall
« Reply #11 on: March 09, 2013, 08:29 PM »
first centre punch rivet
then use a 3mm drill bit for a pilot hole then use a larger drill to remove rivet,as far as i can remember 6mm
or if you want pop it in the post and i will do it for you ;)
Offline Devilock
« Reply #12 on: March 09, 2013, 09:18 PM »
Sounds good to me Phil!! :D
Offline GavinDavis
« Reply #13 on: March 09, 2013, 09:32 PM »
Dont be frightened Rich......get yourself a power tool  :daumenhoch:
Offline glenboy
« Reply #14 on: March 09, 2013, 10:09 PM »
yep rich did it on the gaystar above and although doesn't look perfect , you can put it back to normal as its only screwed in different , the only thing i needed was the dome washer (improvised) on the cable holder on the caliper , and the brake worked perfect
Offline Devilock
« Reply #15 on: March 09, 2013, 10:19 PM »
Ive got one
Offline Devilock
« Reply #16 on: March 09, 2013, 10:23 PM »
I want it the same as Neil's so its the drill...!
Offline GavinDavis
« Reply #17 on: March 10, 2013, 12:59 AM »
Ive got one
Holy crap Rich! Thats a proper tool!  :LolLolLolLol:
Offline glenboy
« Reply #18 on: March 10, 2013, 01:36 AM »
yeh its the pervy version of nosey bonk
deeman
« Reply #19 on: March 10, 2013, 04:09 AM »
Anyone for a bumming?? :-\
firebird
« Reply #20 on: March 10, 2013, 12:26 PM »
I filled the back off one last week, no drilling needed
