976239 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 06, 2026, 08:27 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Un-doing an Epoch (GT) headset ..... (Removed)... Thanks .
Author Topic: Un-doing an Epoch (GT) headset ..... (Removed)... Thanks .  (Read 1843 times)
Offline Funkyworm
Any ideas how to do this ?
Ive taken off the top bolt & spring cover , does the rest just unscrew ???? Never had one of these & I don't want to be heavy handed & break it as it'll be up for sale..
« Last Edit: April 04, 2013, 05:29 PM by Funkyworm »
Offline That Swan Guy
Re: Un-doing an Epoch (GT) headset (Help)...
« Reply #1 on: April 04, 2013, 05:20 PM »
You need to take the spring out then the rest will unscrew as normal :daumenhoch:
Offline Andy68
« Reply #2 on: April 04, 2013, 05:25 PM »
x2....... just ping it out of it's recess with a little flat screw driver, get rough with it!!!   :daumenhoch:
Offline Funkyworm
« Reply #3 on: April 04, 2013, 05:28 PM »
All sorted, I looked a bit closer to realise that it just pinged out...
Thanks again !
« Reply #4 on: April 04, 2013, 05:32 PM »
Shut it Hippie, I answered first!  :-*
Offline Hiro Tonka
Re: Un-doing an Epoch (GT) headset ..... (Removed)... Thanks .
« Reply #5 on: April 04, 2013, 05:48 PM »
dib dobs if it a freestyle version  ::)
Offline Andy68
« Reply #6 on: April 04, 2013, 07:31 PM »
Your answer was just too vague!!!  :Aresehole:
So is there rocket science involved re fitting?? Should there be a correct tension? Never had any problems with them but I just slide it down in the fork recess, twirl the fooker round and slot the other end wherever it'll go! Ingenious idea!  :)
« Reply #7 on: April 04, 2013, 07:33 PM »
Oh dear!
 :-X
Offline Andy68
« Reply #8 on: April 04, 2013, 07:47 PM »
Again, not much of an answer!!!!!!  :LolLolLolLol:
