Springfield brake problem
ED209:
--- Quote from: QUADROPHENIA on April 04, 2013, 08:54 PM ---
You haven't got it on upside down have you ed ? See one the other week
--- End quote ---
that could be it Pierre ... I put it on facing down like a 990 ... will try it the other way up :daumenhoch:
ED209:
hold on ... both arms are the same ??? how can you get it upsidedown?????
LENNY-LENTINI:
Haha
I put mine on upside down at first and flipped a right rage until I realised the bolts weren't long enough because it was on wrong.
Just flip it over Ed.
Oh and get to Asda for some laggy's.
Faith. L
ED209:
--- End quote ---
Finally got to sit down and look at my brake ... Master Pierre was of course spot on - I guess thats the benefit of being one of the chosen ones with the halos ... you are always right :daumenhoch:
... which was confirmed by the LLP representative 8)
Turned it over and all is well.
So I call BS on the review I read which said they were cheap as the calipers were from the same cast ... no way if both sides are recessed for the bolts when mounted :crazy2:
Had no probs with mine when I went for a spin today .. even when they were upsidedown ^"^
not johndub71:
I had this with an oddy evo2. Mine was the brass inners of the u brake were too long. The bolts and washers are supposed to tighten to the lug on the frame. Mine just crushed the brass inner.
Navigation
[0] Message Index
[*] Previous page
Go to full version
