976239 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 06, 2026, 05:53 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Skyway Axle Length.
Author Topic: Skyway Axle Length.  (Read 1900 times)
Skyway Axle Length.
« on: April 07, 2013, 06:41 PM »
Has anyone got an 80s Tuff axle that they could measure for me please?  ???
Or does anyone know the length off the top of their heads??
I've got a new set with the quite large axles and Daz has kindly offered to cut them down and and dome the ends for me. :daumenhoch:
Offline HARORIDER
Re: Skyway Axle Length.
« Reply #1 on: April 07, 2013, 06:49 PM »
i think they are 6" mate  :daumenhoch:
« Reply #2 on: April 07, 2013, 06:54 PM »
Cheers dude, I was expecting the first reply from Bendy. ;)
Thanks again. :4_17_5:
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« Reply #3 on: April 07, 2013, 08:17 PM »
Wasn't the rear slightly wider?
dj B silverlite
« Reply #4 on: April 10, 2013, 03:16 PM »
Yeah Jaan ur right the rear is longer. by half inch or slighly more. ive some at home I can measure them  tonight if you like. :daumenhoch:
« Reply #5 on: April 10, 2013, 03:45 PM »
Would be great if you could please mate.  :4_17_5:
« Reply #6 on: April 10, 2013, 07:32 PM »
 ;D  sorry been working
I would tell you, but my stuff is in the loft at the mo and Lilly is a sleep so can't wake her
an other idea if it is for a certain frame, is the measure the rear drop outs - they will pull in slightly when tightening up, but you will also know that you haven't gone too short when having them cut  ;)
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« Reply #7 on: April 14, 2013, 12:02 PM »
Not sure if you ever got a definitive answer to this Dan but I just measured a set of alloy hub axels and got:
Front - 134mm
Rear - 150mm
Chris  :daumenhoch:
« Reply #8 on: April 14, 2013, 12:26 PM »
Front - 134mm
Rear - 150mm
Chris  :daumenhoch:
Cheers Chris, I'd forgotten that I'd not had a solid answer.
I'll post mine off to Darren this week.
Thanks again matey. :daumenhoch:
dj B silverlite
« Reply #9 on: April 15, 2013, 07:19 PM »
sorry mate I completely forgot  :-[
« Reply #10 on: April 15, 2013, 08:23 PM »
Don't worry bout it pal. :daumenhoch:
