976238 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 05, 2026, 06:35 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Whats missing? Help please!
Author Topic: Whats missing? Help please!  (Read 2437 times)
Offline bmxgirl
« on: May 09, 2013, 06:33 PM »
Basically what goes on next? apart from the obvious handlebars lol
The forks are tightly in place and wont fall out but i don't know what other bits are missing!
Offline wildon
Re: Whats missing? Help please!
« Reply #1 on: May 09, 2013, 06:44 PM »
supposed to be just the top nut but you have loads too much thread left over there .. you gonna need to cut some off or whack a load of washers on before the top nut
leehunt1
« Reply #2 on: May 09, 2013, 06:56 PM »
Take your pick, Hot or Cold  ;D
Offline bmxgirl
« Reply #3 on: May 09, 2013, 07:37 PM »
lol @ above!
Wildon - yes thats what i thought. I guess maybe it was meant to have a gyro which would fill the gap. Ile have to just put spacers on.
Offline wildon
« Reply #4 on: May 09, 2013, 07:40 PM »
gyro still wouldnt fill the gap .. they move up and down over the headset
Offline stuntmaster
« Reply #5 on: May 09, 2013, 07:50 PM »
yep shouldn`t have that much thread left , you could use spaces but odd that it has so much thread left
no1stuntmaster on instagram
Offline wildon
« Reply #6 on: May 09, 2013, 07:53 PM »
prob a stupid question but the cup, crown race and bearings are on the bottom of the headtube right?
Offline bmxgirl
« Reply #7 on: May 09, 2013, 08:13 PM »
Not a stupid question at all. As far as i know those bits are on the bottom. Whats a crown race tho ?  :-[
Offline Taipan
« Reply #8 on: May 09, 2013, 10:18 PM »
Mind the gap!  :D
« Reply #9 on: May 09, 2013, 10:25 PM »
different headsets look different! but essentially you need all these bits
« Reply #10 on: May 09, 2013, 10:57 PM »
It looks like your fork steerer is too big for your head tube.
Are A-head head tubes smaller than inch ones? I only ask as the Giro lug points to it being a new skool frame which don't usually have threaded forks.
Offline not johndub71
« Reply #11 on: May 10, 2013, 10:37 AM »
Stick a few ahead spacers in then fit top bolt.
Facebook/Fr35Hair
« Reply #12 on: May 10, 2013, 11:00 AM »
more pics and info on the bike needed  :)
« Reply #13 on: May 10, 2013, 11:29 AM »
I think you may have it there Bob, 1 1/8th headtube/headset with threaded forks  ???
Offline GavinDavis
« Reply #14 on: May 10, 2013, 11:44 AM »
It has to be a 1 1/8th headset as it looks to be using a compression ring to take up the slack of the steerer inside the head tube  :daumenhoch:
What bike is it?
Offline Munnyella
« Reply #15 on: May 10, 2013, 02:11 PM »
1&1/8 threaded?  I've got some mongoose ones, mine has the stem next, then a fook off big top nut to compress it all down, horrible, but works.
May not be enough thread if thats the case....
MM
Offline bmxgirl
« Reply #16 on: June 03, 2013, 05:06 PM »
The bike is a Reef Boss (yes i know pos)! But i enjoy i building parts bin specials, although if i can't fit the forks ile give up!
Heres what i have...
