My seatpost is stuck , no (not in my ass) in my frame... please help...
ED209:
Callum I knew this was you just be reading the title ;D
ED209:
you best bet is leverage :)
clamp an old stem onto the post... put a piece of pole over the stem's 'stem'... put the frame on the floor...stand on it... push the pipe down ( gently back and forth )
The alloy post will either work loose and come out or snap off ... then you need to melt it out :daumenhoch:
spadey99:
Only Success ive had mate is heat........ But very very carefully....... :tickedoff:
Funkyworm:
--- Quote from: ED209 on May 17, 2013, 06:32 PM ---you best bet is leverage :)
--- End quote ---
Sounds interesting, ok well tonight i literally ripped the vice off of the bench (it was only G-clamped on but the whole of the bench top came off !!!!! Grrrrr been on the Protein (Not)...
Filled the post & frame with gt 85 sealed the end with plastic bags & tape & flipped the frame upside down to see if it works it's way between the post & frame on from the insde of the frame.
I'll leave until Sunday & If i cant get it out of the frame Im considering cutting down the post then getting out the dremel & cutting down the recess at the back of the frame hen start cutting the post from the inside of the post outwards towards the frame if that makes sense ?
oldschoolace:
The key thing is to break the "corrosion weld" by knocking the post down a bit first. Should twist out a treat then :daumenhoch:
Navigation
[0] Message Index
[*] Previous page
Go to full version
