976238 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 05, 2026, 10:54 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  My seatpost is stuck , no (not in my ass) in my frame... please help...
Author Topic: My seatpost is stuck , no (not in my ass) in my frame... please help...  (Read 2075 times)
Offline Funkyworm
Ok so im sure this has happened many times before but I have a Renthall seatpost that came with a bike i purchased the other day & it's  severely stuck in place in the frame  , i've tried spraying gt75 every day for the last 4 days where it enters the frame & also down inside the post in to the frame & then turning the frame upside down in order to get the oil to soak in from the inside . Then i've had it in a vice but it will not move at all.
Any methods that have worked for you guys wold be greatly appreciated as this is annoying the hell out of me.
Cheers :daumenhoch:
Ah the old stuck seatpost conundrum  :smitten:  :LolLolLolLol:
First things first is the frame ali or steel?
Offline Funkyworm
it's a 531 frame !
Ok so melting it out gradually with caustic soda is a final option  :D
First try giving the post a sharp smack down further into the tube with a hammer to break the "seal" then try it in the vice again
If its slipping in the vice drill a hole throught the top of the post big enough for a decent sized alen key or something similar and try in the vice again
Other options are:
Cutting down the lenght of the post with a hacksaw blade, a ballache!
Drilling out with the right sized bit, difficult  :(
Heat? not the greatest of ideas usually
A bigger vice  ;D
Offline Funkyworm
Other options are:
A bigger vice  ;D
Ok I'll get back on it n the morning , Cheers for the er  (options)  :daumenhoch: :daumenhoch: :daumenhoch:
Callum I knew this was you just be reading the title  ;D
you best bet is leverage  :)
clamp an old stem onto the post... put a piece of pole over the stem's 'stem'... put the frame on the floor...stand on it... push the pipe down ( gently back and forth )
The alloy post will either work loose and come out or snap off ... then you need to melt it out  :daumenhoch:
Offline spadey99
Only Success ive had mate is heat........ But very very carefully.......  :tickedoff:
Bikes are there to be ridden, so why do I have so many.....
Offline Funkyworm
Sounds interesting, ok well tonight i literally ripped the vice off of the bench (it was only G-clamped on but the whole of the bench top came off !!!!! Grrrrr been on the Protein (Not)...
Filled the post & frame with gt 85 sealed the end with plastic bags & tape & flipped the frame upside down to see if it works it's way between the post & frame on from the insde of the frame.
I'll leave until Sunday & If i cant get it out of the frame Im considering cutting down the post then getting out the dremel & cutting down the  recess at the back of the frame hen start cutting the post from the inside of the post outwards towards the frame if that makes sense ?
The key thing is to break the "corrosion weld" by knocking the post down a bit first. Should twist out a treat then  :daumenhoch:
