976238 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 05, 2026, 05:21 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  wheel axle setup
Author Topic: wheel axle setup  (Read 1955 times)
Pottinger
wheel axle setup
« on: May 28, 2013, 09:44 AM »
hey all
sorry for a real basic question here but ive tried searching and think im getting myself confused  :-[
I have a pair of original skyway tuff ii's (rear is alloy hub) and they came with no spacers/bolts ...
Can anyone give me a heads up on fitting....
ie
from what i can see the front looks like it should have some spacer both sides on the inner side of the fork and the securing bolt
on the outer side of the fork ...
The rear looks like you slide the axle straight in the frame follwed by the securing bolt on outside of the frame ...or are there spacers somewhere on the rear too ??
Also, what size bolts are they ?
I am so sorry for such a basic question but I dont want to add just any old thing in the hope its correct, so any help is
very much appreciated...
cheers
potts
Re: wheel axle setup
« Reply #1 on: May 28, 2013, 10:05 AM »
Pottinger
« Reply #2 on: May 28, 2013, 10:31 AM »
cheers for that, still a little confused tho  :-[
looking at mine, the axle parts are fine, just the attachement to the frame and forks im trying to get to grips with lol.
looking at pic 1, i presume i need the nut and serated washer ?
does that washer go inside or outside the frame ?
sorry to be a pain  :'(
cheers
potts
« Reply #3 on: May 28, 2013, 11:22 AM »
I would put the nut and a washer outside of the frame drop out and the rest inside.
Pottinger
« Reply #4 on: May 28, 2013, 03:26 PM »
ok so in my cleaning quest i have pulled the front axle to clean it and noticed the bearings need greasing.
is LM grease ok ? or should i use something specific ??
ta
potts
« Reply #5 on: May 28, 2013, 07:55 PM »
most bike grease will be fine
thicker if you want to keep it sealed more and lithium if you want it to spin faster
cheers  B  ;)
