976238 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 04, 2026, 06:40 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Another seat tube dilemma.
Author Topic: Another seat tube dilemma.  (Read 2406 times)
Offline CustardLips
« on: July 01, 2013, 06:49 PM »
Seat post is stuck in this one !  >:(
Any tips ?  :)
"WWG1WGA"
Offline Dannywhac
  • return of the whac
Re: Another seat tube dilemma.
« Reply #1 on: July 01, 2013, 07:00 PM »
Soak in diesel or a lube/de-ruster of your choice overnight.
Get an old stem, clamp the four-bolter part of stem around seattube, twist and lift  :daumenhoch:
« Reply #2 on: July 01, 2013, 07:15 PM »
Whats stuck in what ?
Offline CustardLips
« Reply #3 on: July 01, 2013, 08:03 PM »
An ally layback in Gt pro frame.
"WWG1WGA"
« Reply #4 on: July 01, 2013, 09:01 PM »
There r other threads in this section with all sorts of ideas  ;) Check em out fella . If all else fails melt it out with caustic  :daumenhoch:
Offline stevochb
« Reply #5 on: July 01, 2013, 11:21 PM »
Aye caustics the way to go but make sure you are well protected. Gloves, visor or goggles and do it in a well ventilated area.
Offline not johndub71
« Reply #6 on: July 02, 2013, 10:06 AM »
clamp a stem to it and rag it out
Facebook/Fr35Hair
Offline fischflo
« Reply #7 on: July 02, 2013, 12:53 PM »
shake it
Offline Funkyworm
« Reply #8 on: July 02, 2013, 08:11 PM »
Im with Steve on this one, Caustic is the way forward I went down this route after trying everything only last month. it took a bit of babysitting but it came out perfectly & this post was stuck in all the way down to the bb casing, Longest bloody seat post i've ever seen mind you the guy i bought this off was about 6ft 4" !
Offline CustardLips
« Reply #9 on: July 02, 2013, 08:33 PM »
Thanks again fella's.  :daumenhoch:
"WWG1WGA"
