976238 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 04, 2026, 06:40 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  What is everyone using nowadays to strip?
Author Topic: What is everyone using nowadays to strip?  (Read 1423 times)
Offline Jamroll
« on: July 02, 2013, 01:57 PM »
I've run out of the normal crap i used,and the gasket cleaner form work does fook all, I know the stuff SBD uses is proper stuff but i really don't need a couple of gallons of the stuff forthe amount of bikes i build,can anyone recommend what they use to strip Powder or help me out with a little of Dans stuff?
Al  :-*
* Now found i need some Synstrip, but don't need 5 ltrs of the stuff, who has got some here i could have, ED209 had some a little while back...anyone else able to help me out..Mattbloke?
« Last Edit: July 02, 2013, 03:28 PM by Jamroll »
Offline Taipan
Re: What is everyone using nowadays to strip?
« Reply #1 on: July 02, 2013, 04:58 PM »
In my experience Synstrip is rubbish,the paint was just as hard to get off as using a cheapo stripper from Wilko's  :-\ seen pictures on here with paint just falling off frames? not so in my experience sorry  :2gunsfiring_v1:
« Reply #2 on: July 02, 2013, 05:02 PM »
Send it to the Chromers Al and let them do the hard work. I just had some painted forks and a Chrome frame stripped and they were back in a day, £60 job done :daumenhoch:
Offline Jamroll
« Reply #3 on: July 02, 2013, 05:35 PM »
Cheers for that Big Fella, but I've only got a head set that needs doing  :)
Offline oldtired
  • Dirty Old Man
« Reply #4 on: July 02, 2013, 06:46 PM »
Rustins Strypit is ok :daumenhoch:   works like nitromose used to before they made it eco friendly  :daumenhoch:  comes in  250 or 500ml tin s too  :daumenhoch:
« Last Edit: July 02, 2013, 06:47 PM by oldtired »
Offline Funkyworm
« Reply #5 on: July 02, 2013, 07:15 PM »
Synstryp does work, for small parts like headsets you need to try to keep the part in a container & pour on . A small  (tupperware container) will do & stick the lid on !
Because of the fumes if you are doing a frame or larger part you really need to work in a well ventilated area or do it outside . Problem with this is it tends to evaporate quickly & it dries up so you need to give it a head start, i've scored the paint or powder with a wire brush before painting or pouring it on & then placed the frame in to a large bin liner (rubble sack) & sealed the top stopping it from evaporating & it works a treat but you need to be patient. On a thick powder it could take a day or so  but it will do the job. :daumenhoch:
