976238 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 04, 2026, 08:08 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  What grease ?
Author Topic: What grease ?  (Read 3195 times)
Offline neil
What grease ?
« on: July 04, 2013, 11:10 AM »
Need to buy some grease what does everyone use?
Offline Dannywhac
  • return of the whac
Re: What grease ?
« Reply #1 on: July 04, 2013, 11:17 AM »
For what Neil? Bearings/BB's etc or anti-sieze stuff for 3-pieces etc?
I use any bog-standard teflon based grease for HS's, and car-lube copper anti-sieze for crankies spindle/peds  :daumenhoch:
And truestory - NEVER use butter for wheel bearings if you've not got any grease, mate of mine did it in the late 80's and was still picking grit out of his face for weeks later  :LolLolLolLol:
« Last Edit: July 04, 2013, 11:19 AM by Dannywhac »
Offline fischflo
Re: What grease ?
« Reply #2 on: July 04, 2013, 11:21 AM »
skf lgmt 2/0.2 general purpose
Offline neil
Re: What grease ?
« Reply #3 on: July 04, 2013, 11:24 AM »
It's for general use headset bearings bottom bracket cups etc,I've got some white stuff in a green tube but its too thin
Links would be handy for the grease ta
leehunt1
Re: What grease ?
« Reply #4 on: July 04, 2013, 11:25 AM »
think this is what u need
Offline Dannywhac
Re: What grease ?
« Reply #5 on: July 04, 2013, 11:30 AM »
To be honest you can shell out a crap load for branded teflon grease, when you don;t need to (it's not like you're gonna be spinning the bearings at 80mph for hours on end), so just pop down your local car DIY centre and buy a £5 tub there.
Or get this:
http://www.tesco.com/groceries/Product/Details/?id=253886894
Offline neil
Offline Glynnyboy
Re: What grease ?
« Reply #8 on: July 04, 2013, 01:28 PM »
I once ordered a bb from the US and part of the deal was a tube of Phil Woods.
It's the best stuff ive used. I need to order some more actually but this time im going to shell out for the big tub.
It smells ace too :-[ :shocked: (yep im a closet phil woods grease sniffer)  :LolLolLolLol:
http://www.ebay.co.uk/sch/i.html?_sacat=0&_from=R40&_nkw=phil+woods+grease&LH_PrefLoc=2&_arm=1&_armm=63&_ruu=http%3A%2F%2Fwww.ebay.co.uk%2Fsch%2Fi.html%3F_sacat%3D0%26_from%3DR40%26_nkw%3Dphil%2Bwoods%2Bgrease%26_arr%3D1
Offline Rabdul06
Re: What grease ?
« Reply #9 on: July 04, 2013, 01:56 PM »
   Dont use silicon grease......I found some and used it to lube my DX bearings as it said it was safe for food use on the side (so I figured if you can eat it then its good enough for the old DX's...!?!?).....anyway when it got warm outside all the grease melted and goop leaked everywhere - nob.
  Just get a tub of cheap stuff from BandQ or somewhere..
Offline GavinDavis
Re: What grease ?
« Reply #10 on: July 04, 2013, 02:39 PM »
Ive got a tube of the Halfrauds red teflon stuff....works a treat!  :daumenhoch:
Offline mattbloke
Re: What grease ?
« Reply #11 on: July 04, 2013, 05:27 PM »
any half decent lithium grease for B/B wheels and headset. copper grease for nuts, spindles, ally fastenings and seatpost/stem insertion. never had one seize that had copper grease on it  :daumenhoch:
Offline not johndub71
Re: What grease ?
« Reply #12 on: July 04, 2013, 06:56 PM »
High melting point lithium. Works on ma car, works on ma bikes.  :daumenhoch:
Facebook/Fr35Hair
Re: What grease ?
« Reply #13 on: July 04, 2013, 09:02 PM »
