976238 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 04, 2026, 07:35 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  crank spindle re threading
Author Topic: crank spindle re threading  (Read 1850 times)
Offline garran
« on: July 28, 2013, 11:42 AM »
morning fellas, can  the threads on a cranks spindle be re-threaded?
cheers
Offline kev-s
Re: crank spindle re threading
« Reply #1 on: July 28, 2013, 07:38 PM »
if its a female crank axle then u have two choices really
get a tap and die and cut a new thread into it and use a slightly larger bolt
or
drill it out slightly larger than the current bolt size and fit a helicoil and then u can use the original bolt size :daumenhoch:
Offline garran
« Reply #2 on: July 30, 2013, 03:39 PM »
cheers Kev its actually on the threads of the bearing race
Offline garran
« Reply #3 on: August 01, 2013, 07:28 PM »
anyone know?
leehunt1
« Reply #4 on: August 01, 2013, 09:52 PM »
Ask Kap..!
Offline garran
« Reply #5 on: August 03, 2013, 06:23 PM »
cheers Lee, just wondering if it could be repaired
redline 84 double dimple 401 spindle, might be of use to someone perhaps??  (was mine from bitd, stripped chainring side from being lazy and not keeping it tight)
Offline Gary72
« Reply #6 on: August 04, 2013, 10:22 AM »
Try a thread file. I used one on a one piece crank awhile back. Worked fine.
