976238 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 04, 2026, 05:01 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Freewheel removal
Author Topic: Freewheel removal  (Read 1460 times)
Offline scoff
Freewheel removal
« on: August 12, 2013, 07:20 AM »
Without a 2 pin tool, is there any easy way of removing this freewheel?
Any tips would be much appreciated.
Re: Freewheel removal
« Reply #1 on: August 12, 2013, 07:24 AM »
big flat screwdriver and hammer  :daumenhoch:
Offline GavinDavis
« Reply #2 on: August 12, 2013, 07:35 AM »
Remove the axle, put a flat length of steel in a vice so that it locates in both recesses and turn it anticlockwise.  It will probably be a bit of a bugger to remove so a bit of downward pressure will be necessary  :daumenhoch:
Offline That Swan Guy
« Reply #3 on: August 12, 2013, 07:37 AM »
Hammer and 6" nail
Offline scoff
« Reply #4 on: August 12, 2013, 09:14 AM »
Wow, fast responses.
I'll try them all, if I've any working fingers after, I'll type which method worked..?
« Reply #5 on: August 12, 2013, 11:27 AM »
Dont try and turn it by the two holes, all you will do is take the freewheel apart and have bearing everywhere! As Gav says its the two flat recesses you need to turn  :daumenhoch:
Offline Dannywhac
  • return of the whac
« Reply #6 on: August 12, 2013, 11:38 AM »
x2 on what Clint said :)
If all else fails and you can't gerrit off and you don't mind sacrificing the freewheel, take the freewheel apart using them two small round holes, remove the toothed wheel and take out the pawls on the freewheel. Where the pawls were are nice big recesses that you can get you screw-driver in and tw@t the bugger off :)
